SOHC.co.uk Forums > CB750
Fork Oil
Spitfire:
Here's the Specs section from the supplement that Honda issued for the CB750F.
The Honda manual for the original CB750 gives a figure of 220-230 cc, but the forks are different to the CB750F ones.
Den
kifer:
Cheers Den, Thanks for taking the time to post spec list, For the lay man like me some of the manuals are a s**t that's the reason I like to check if not sure. some questions I ask must sound a bit mainstream to you lads Thanks again.
Spitfire:
I can see where the confusion comes from, I looked at the specs in a few of my genuine Honda manuals (not Clymer or Haynes) and got the following
CB750 (Original CB750): 220 - 230cc
CB750K2, K3, K4: 220 - 230cc from dry, 155 - 160 after draining.
CB750F: 145 - 155cc
CB750F2: 1977 145 - 155cc
CB750F2 and K8: 135 - 145cc from dry and 145 - 155 after draining.
Den
billy192:
Hi,
I am just about to change the fork oil in my 1976 K6.
Am I correct in thinking it is 220 - 230cc from dry, 155 - 160 after draining?
Waggles:
Think the forks were basically the same until the F1 so yes you are correct, F1 and F2 as quoted above, not sure about K7 but I assume same as F1
Navigation
[0] Message Index
[*] Previous page
Go to full version
