SOHC.co.uk Forums > CB500/550
New head gasket blowing and lumpy as hell ...
<< < (3/3)
matthewmosse:
In a word the sound of a sohc 550 running on 2 is rough. I didn't video it but I did g
et several miles home with a snapped camshaft once with a sidecar and passenger. It was hesitant to rev under load and spat and backfired a lot.
Bryanj:
If you have used ordinary jubilee clips there will be an air leak! The honda ones are narow and are the only type that seal properly
madoc:
--- Quote from: Bryanj on September 03, 2012, 06:57:31 AM ---If you have used ordinary jubilee clips there will be an air leak! The honda ones are narow and are the only type that seal properly
--- End quote ---
Oh bum
Are these the £4 each parts from David Silver ...
A couple of rubbers are not great (and not cheap) - is there another source ...
An update is that I have the bike revving but its still not quite right.
I'll own up to not tightening an exhaust rocker adjuster nut and was effectively running on three... I also had the breather jamming the carbs ...opps
I can see u are in Gloucester. I am in Lea (between gloucester and Ross). Small world.
Bryanj:
I thought thr carb to head rubbers were quite a reasonable price and yes the clips you need are the £4 each fron DS or possibly i have seen stainless ones from specialists but not sure where
madoc:
it's the carb to airbox rubbers, where they are not the best, and now fastened with jubilee clips.
Navigation
[0] Message Index
[*] Previous page
Go to full version
