SOHC.co.uk Forums > CB350/400
front end
steven400/4:
what so both calipers are on top and at the front???
Bryanj:
Yes BUT the forks are a bigger diameter so you need the yokes as well
steven400/4:
thanks i,ll have to try and find some
Bryanj:
550 four are the same as well
Captain Snakebite:
CB400n forks are 33mm diameter - they should slide straight into the original triples.
http://scandalon.com/2009/06/motorcycle-fork-diameter-chart/
500 or 550 hub, laced into an 18", 40-hole rim keeps the speedo setting nice and can take two discs up front.
Navigation
[0] Message Index
[*] Previous page
Go to full version
