CB750
Front brakes
Topic: Front brakes (Read 5048 times)
steve underwood
Newbie
Over engineered unlike the rider
Front brakes
October 08, 2012, 01:43:20 PM »
Can anyone recommend some decent brake pads or an alternative front brake caliper for a 750 f1, it isn't the fastest bike in the world but its up there with the slowest to stop!
Steve
mick
Re: Front brakes
October 08, 2012, 01:57:52 PM »
Hi Steve don't think there is an alternative front caliper without changing the front end?,
if you have braided hoses and the caliper bled & set up correctly there not that bad for stoopping, your other alternative is to fit a twin brake set up
cheers Mick.
UK Pete
Re: Front brakes
October 08, 2012, 02:20:11 PM »
I agree with micks comments, also perhaps fitting of sintered pads, degrease your disk and put new pads of your choice in and it should be better, my K1 seems to stop as well as my f2 , the k1 has single disk the f2 has twin set up, so there is hope for 1 disk set up
Also i find new pads take a while to settle in and give best performance
Pete
Link to my Diecast K0 restoration
http://www.sohc.co.uk/index.php/topic,4827.0.html
Link to sandcast restoration
http://www.sohc.co.uk/index.php/topic,6862.0.html
Waggles
SOHC Expert
Re: Front brakes
October 08, 2012, 02:34:41 PM »
Agreed, in the dry with my F1 I don't have too much to complain about. If you are used to modern brakes and 2 finger squealies then you will be disappointed, but I find if you really grab a handful she stops quite well. Lever movement is probably more than modern bikes too but that can help with the control. As previous ensure the brake is well set up and caliper / master cylinder overhauled. Agreed braided lines help too.
In the wet not so good though, I keep dabbing mine in the rain to clear the discs .......
Re: Front brakes
October 08, 2012, 03:46:56 PM »
Its not the slowest to stop by a long way, try a pre-unit Triumph with a 7 inch SLS drum!!
It is, however, a lot worse than the new stuff you are comparing it too
r1_pete
SOHC Member
Re: Front brakes
October 24, 2012, 08:30:34 PM »
You could go for a master cylinder with a smaller bore, this has the effect of increasing the laver to pad movement ratio, so for the same pressure on the lever, you get more pressure at the pad.
Take a look here:
http://www.vintagebrake.com/mastercylinder.htm
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Bitsa (Ralph Wright - RIP)
Re: Front brakes
October 24, 2012, 08:50:52 PM »
Come one guys you are riding bikes way back in technology would you fly a spitfire aircraft the way the way it was invented today?
Get real stop moaning the disc in that day was the bollocks comapare to the crap the Brits had.
You know it
Rergards
Bitsa
r1_pete
SOHC Member
Re: Front brakes
October 24, 2012, 10:18:55 PM »
Agree Bitsa, but back then the CB could out brake the Alegros Cortinas and the likes in traffic, now my L200 truck will out brake the CB easily.
So a bit of extra stopping power is welcome in my book, providing the tyre can handle it.....
Same with my E Type Jag, I've spent more on brake mods than the whole F2 has cost me.
1971 CB450
Seamus
Re: Front brakes
October 24, 2012, 10:40:22 PM »
If you want to go the whole hog, have a look at this
http://www.stotfoldengineers.co.uk/stotfold_engineering_blog/2010/01/19/hydraulic-brakes-problems-and-solutions-to-common-faults/
give Terry a call to discuss
r1_pete
SOHC Member
Re: Front brakes
October 25, 2012, 10:19:42 AM »
Looks neat, I'm using 82 CB900 twin piston calipers on my 750F2, with a CBR600 1/2 bore master cylinder, and braided hoses caliper to caliper to cut down on joints, should give a nice progressive feel.
1971 CB450
CB750
Front brakes
