Author Topic: Steering Lock Key  (Read 21708 times)
Offline tom400f
Steering Lock Key
« on: December 27, 2012, 04:06:13 PM »
I have never had these for my bike. Is it possible to get just the key or does the barrel have to be replaced?
Above the key hole is stamped the number "19" - otherwise the lock is anonymous. Then there is the metal disk riveted on, which I assume has to be drilled out to remove the barrel if keys cannot be obtained separately.
Apologies for rubbish picture
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Re: Steering Lock Key
« Reply #1 on: December 27, 2012, 04:49:09 PM »
You could ask a GOOD Honda dealer like D.S.S. if you can get one from the frame number. Failing that I dont really know. What I do know is that just drilling out the rivet does NOT free the barrel, as it needs to be turned with the key about an eighth of a turn anti clockwise to be able to disengage a tongue on the inside end of the barrel to release it from the headstock. Thankfully the barrel is brass, so on my 750F1 (same lock) I got a drill as close to the diameter of the bit of the barrel that turns (think it was 8 or 9mm, bearing in mind it was 20 odd years ago! :-\) and on a very slow speed, drilled it down till I hit the steel bolt (about 20mm) that is behind the barrel, then put a large screwdriver into the remains of the barrel, and managed to turn it anti clockwise and out it came ;D  Hope this helps
Offline tom400f
« Reply #2 on: December 27, 2012, 08:36:33 PM »
Thanks for that hairygit. I've mailed DSS.
1978 CB400F2 Yellow
« Reply #3 on: December 28, 2012, 12:29:31 AM »
You will find the answer is no as its a neiman lock and they don't supply blanks or spare keys.
CAREFULLY  pull on the disc till the rivet comes out as you will need to re-use it then drill out the brass with a 12mm drill bit till the lock comes out. Keep the spring as the new one don't come with it.
Lock key has to be turned to insert barrel then re-insert rivet and disc
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Lobo
« Reply #4 on: December 28, 2012, 04:39:06 AM »
Tom - sorry to hijack your thread a little...
My 400 is a little 'oddball' in having '77 F2 American frame / engine numbers, which include the swing arm footrests. All the other bits; tank, footpegs, handlebars, lights etc are UK spec. But from this thread I now learn the steering lock may be different - ie mine is operated via the ignition key.
Q. I was considering 'upgrading' my frame to the later UK (E) one with loop pillion footrests - but now ask if in doing so I'll loose the steering head frame configuration and have to revert to a separate lock system? (ie given the choice I'd stick with my ignition operated steering lock, and perhaps save considerable work in the process.)
Cheers & thanks...
« Last Edit: December 28, 2012, 05:26:49 AM by Lobo »
« Reply #5 on: December 28, 2012, 06:11:41 PM »
To the best of my knowledge all the UK 400's had the seperate steering lock, but having said that if you check the ignition lock it simply extends a hardened pin to lock against something on the frame so , in theory , should be possible to fit
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #6 on: December 29, 2012, 05:08:31 AM »
Cheers Bryan - will have a look but unsure of how I'd know without having the 2 frames side-by-side to compare. My parts PDF - kindly supplied by Peter (Kent400) - does not clarify. You gotta ask just why Honda would go to the expense / trouble of 2 different locking systems - I originally figured  some 'elf'n'safety issue - but cars have long had steering locked by the ignition key.
Thanks again.
« Reply #7 on: December 29, 2012, 03:52:59 PM »
Honda were not always logical mate, theywere still making the 500K1 for the UK when the states had theK2 and the 550
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Lobo
« Reply #8 on: December 31, 2012, 08:44:43 AM »
Cheers all,
The attached (English & American frames) putting pictures into words. My (American) ignition lock has a protruding pin which locks against the upper headstock flange.
Thanks for the various helps,
Lobo
« Last Edit: December 31, 2012, 08:46:46 AM by Lobo »
Offline tom400f
« Reply #9 on: January 19, 2013, 06:05:29 PM »
Thanks to Bryanj and hairygit for their advice above. This is all fixed.
I used a claw hammer to lever out the rivet then a 6mm drill, which takes out the internals only. Once I got to more or less the key depth the lock can be twisted with a screwdriver. Last picture shows the locked position.
Thanks again
Tom
« Last Edit: January 20, 2013, 09:36:01 AM by tom400f »
1978 CB400F2 Yellow
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #10 on: May 07, 2014, 09:50:42 AM »
I had a go at replacing my steering lock last night. I had to as I haven't got any keys for the one on there. It took a while to get the old one out. I started with a 4mm drill before going up to the 6mm. I still couldn't get the centre piece out, or turn it at all. I ended up drilling out the whole center piece with a 9mm drill bit, then using a small Allen key hooked into one of the internal slots, I managed to pull the lock out with mole grips on the Allen key.
Now I'm not used to this type of lock but looking at the design, am I right in thinking the whole lock needs to slide in and out of the housing and the steel bit at the end should locate into a hole in the steering stem? My steering stem doesn't have a hole in it!
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline Lynx
« Reply #11 on: May 07, 2014, 07:42:46 PM »
I think you are right Oddjob. I can see down the lock hole well and there is definitely no hole on the stem! This probably explains why The stem isn't long enough to get the washer under the steering stem's top nut :o.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #12 on: August 20, 2014, 08:00:22 PM »
Hi gents. I have a 1972 500/4 imported from Italy.
It has the yoke in the attached pic which I feel sure is not correct.
I have the correct yoke to replace it with, on which the lock has a plastic cap with a dust cover tab on a sprung shaft like my old UK 72 bike.
Just curious to see if anyone knows what the Neiman one is off, and whether it's of interest.
Regards Jerry
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline Lynx
« Reply #13 on: August 20, 2014, 09:03:30 PM »
That's totally different to the 400.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline JezzaPeach
« Reply #14 on: August 20, 2014, 09:33:05 PM »
Maybe a 450 twin, or 350/4?
