Author Topic: Honda cb550 cafe racer build northern Ireland bike finished  (Read 45477 times)
Re: Honda cb550 cafe racer build northern Ireland
« Reply #15 on: February 01, 2013, 01:00:14 PM »
good plan with the black XS engine-----doesn't show the oil leak from the cam cover that came as standard as bad!!
Offline stuartni
« Reply #16 on: February 01, 2013, 03:47:02 PM »
sorry foot to let you know i was putting these up to let you see as said budget was very small on this think we spent around £400 on it so pretty happy with it for spending so little still got full service new bearings fork rebuilt new cables new shocks headlight brackets seat pod new handlebars etc
Offline stuartni
« Reply #17 on: February 06, 2013, 09:17:33 AM »
a few more updates work has been slow but rims and one disc are away to be powder coated and both discs are now drilled in my design
alot of wiring has been done loom shortened and repaired where needed looks messy but isnt really
controls prepped primed and painted
working out where to put my led lights for oil pressure turn signal neutral and full beam
Here worked out good for two of them
Offline stuartni
« Reply #18 on: February 07, 2013, 01:13:42 PM »
rims and disc back from the being shot blasted and powder coated  8)
Offline stuartni
« Reply #19 on: February 19, 2013, 12:42:37 PM »
more updates wheel built tyres on rear brake plate nightmare fixed thanks to norniron400f
30 some odd old brake shoes didnt want to stay together  :-[
tyres are avon road rider 130/80/18 rear and 100/90/19 front
Offline mick
« Reply #20 on: February 19, 2013, 12:57:07 PM »
Wow your doing a great job keep it up and keep the photos coming  8) cheers Mick.
Offline stuartni
« Reply #21 on: February 19, 2013, 02:31:31 PM »
thanks very much and yes really happy with how its all looking so far should have the tank and seat pod back in the next week or two just need to decide on a colour   :-\
Offline stuartni
« Reply #22 on: February 20, 2013, 11:33:57 AM »
more updates rims build tyres fitted etc
disc painted just need lacquer
rear wheel ready to go on
bike rolling again
now with twin disc setup have to modify the disc and standard speedo drive alot to let them fit together
Offline stuartni
« Reply #23 on: February 20, 2013, 09:40:46 PM »
Standard rims  and yes read a few different ways of doing it and woulf of dobe your way if I thought of it befire geting the hub powder coated and built but my way will still work fine and do the job all being well
Offline stuartni
« Reply #24 on: February 21, 2013, 03:08:18 PM »
yes i do agree with tyre size with the rim i used the rear tyre as i already had it sitting there plus a friend of mine has been running a 130 rear and has been happy with it but i do completely agree with what your saying in regards to the handling. As for the twin disc setup i explained myself wrong i didnt modify the speedo drive i modified the the speedo plate and the disc for the lock tabs to sit in.thanks
« Reply #25 on: February 21, 2013, 04:25:33 PM »
425 = 4.25" = 108mm
So a 425/85 is equivalent to a 110/85 in modern speak.
Offline stuartni
« Reply #26 on: February 24, 2013, 06:01:40 PM »
Newest addition to bike family found this thanks to norniron400f he seen it phoned me and on the fridsy night and I bought it the next morning its a cb550 with a cb650 engine has electronic ignition and box loads of parts
Offline stuartni
« Reply #27 on: February 27, 2013, 12:15:43 PM »
few more updates finished some more of the wring and connected up the battery
ignition relocated to here doesnt look in the best order but works fine matched the tank lock
carbs where taken all cleaned inside and out then painted ready to go on
Offline LesterPiglet
  • 1977 CB550F2
« Reply #28 on: February 28, 2013, 01:36:48 AM »
You don't have a spare tacho in that box do you Stuart?
Sent from my GT-S5363 using Tapatalk 2
Offline stuartni
« Reply #29 on: February 28, 2013, 12:26:14 PM »
i do indeed but condition is unknown i will check later see what its like
