Honda cb550 cafe racer build northern Ireland bike finished
3
4
Topic: Honda cb550 cafe racer build northern Ireland bike finished (Read 44889 times)
stuartni
SOHC Member
Re: Honda cb550 cafe racer build northern Ireland
Reply #30 on:
February 24, 2013, 06:01:40 PM »
Newest addition to bike family found this thanks to norniron400f he seen it phoned me and on the fridsy night and I bought it the next morning its a cb550 with a cb650 engine has electronic ignition and box loads of parts
stuartni
SOHC Member
Reply #31 on:
February 27, 2013, 12:15:43 PM »
few more updates finished some more of the wring and connected up the battery
ignition relocated to here doesnt look in the best order but works fine matched the tank lock
carbs where taken all cleaned inside and out then painted ready to go on
LesterPiglet
1977 CB550F2
Reply #32 on:
February 28, 2013, 01:36:48 AM »
You don't have a spare tacho in that box do you Stuart?
Sent from my GT-S5363 using Tapatalk 2
stuartni
SOHC Member
Reply #33 on:
February 28, 2013, 12:26:14 PM »
i do indeed but condition is unknown i will check later see what its like
stuartni
SOHC Member
Reply #34 on:
March 08, 2013, 10:07:28 AM »
little bit of an update havent had much time at the bike but thanks to scott s of the america sohc forum we did a trade he needed shorter rear shocks i needed longer rear shocks to stop the rear end bottoming out, they came all the way from south carolina . Have also made and painted a speedo drive bracket to stop it from hitting the disc and half way through making a rear number plate bracket. Got the horn on as well but going to take it off again and paint the bracket.
made amazing private reg i got with the other cb550 XOI 5504
Ewan 500 K1
jings crivens help ma boab
Reply #35 on:
March 08, 2013, 08:34:21 PM »
beautiful Stuart ... what length rear shocks did you get . prob need to do that to mine too
500K1/550K3 mongrel cafe racer project for now at
http://www.sohc.co.uk/index.php/topic,4120.0.html
500K1 basket case for later
stuartni
SOHC Member
Reply #36 on:
March 09, 2013, 10:25:47 AM »
Thanks ewan there 14.25" standard seem to be 12" the guy i got these from said they came off a cb750 if that helps any
stuartni
SOHC Member
Reply #37 on:
March 12, 2013, 11:07:00 AM »
small update
rear brake setup finished just need paint the bracket etc
bracket made for the brake fluid bottle and throttle cables fitted
stuartni
SOHC Member
Reply #38 on:
March 19, 2013, 12:45:10 PM »
carbs fitted
had a good few electrical problems which have all been sorted thankfully just a few silly mistakes on my parts
only thing to fix is my horn button
Reply #39 on:
March 20, 2013, 06:28:21 AM »
from experience the bend on the speedo cable is too tight mate
stuartni
SOHC Member
Reply #40 on:
March 20, 2013, 09:01:35 AM »
ahh really i was looking at it again last night thinking the same thing to be honest
have to see about changing it
stuartni
SOHC Member
Reply #41 on:
March 20, 2013, 11:48:17 AM »
exhaust trail fit done, the tail piece is not being used its just being used at the moment to work out the design
stuartni
SOHC Member
Reply #42 on:
April 02, 2013, 10:33:24 AM »
more update progress has been slow lately down to the last few little issues to sort out and things i want to redo
got my tank and seat pod back and in primer seat pod needs a little more work i had it back to trim it so it sits clean against the frame
the two hogs
wifes uncles new pet
stuartni
SOHC Member
Reply #43 on:
April 16, 2013, 12:05:57 PM »
small update been away in england with work bike is coming on well with very few jobs left will get some more photos tonight just one i have at the moment of the speedo fitted
stuartni
SOHC Member
Reply #44 on:
May 02, 2013, 10:36:44 AM »
the last few parts i need arrived from david silvers
new chain and link
two genuine honda calliper springs
new pull throttle cable as the one i bought from another company 6 months ago was wrong push cabel was correct
2 new bleed nipples
2 new calliper seals
2 stainliss steel calliper pistons
new oil pressure switch
bike nearly done now
3
4
