SOHC.co.uk Forums > CB350/400
Engine painting
<< < (3/3)
UK Pete:
I have used sand many times, i find it perfect, however the dust is a big health problem, if i use it in my blast cabinet i have an extractor/filter running so the fine dust is instantly removed plus you can see what your doing i also wear a mask just incase any dust is escaping
i find it easier to use than the aluminium blast media  that sells for over 40 pounds a tub, it is cheaper and gives a better finish
Beware of the dangers though silicosis of the lungs through breathing in the dust is becoming a big problem, even when you sweep the silicon sand in to block paving drives you are now advised to wear a mask, people who work in the building industry are at risk
like anything know the risks and be sensible
ST1100:
Are crushed nutshells avail for regular people? Cause that's what's used by the shops refurbishing aluminum wheels fur cars.
sweetpeauk:
On my engine I had the crankcases Vapour blasted and then the top case painted in 2 pack, the barrels are NOS so are still bare ali, the head vapour blasted. I have a set of cases painted to match the top case and a fitted set polished.
boilermaker1:
Again thanks for advise and photo's..
I may now have cases polished, what brand or type of lacquer should I use?
Lynx:
Wow! I thought I'd done a good job but THAT engine is lovely. Well done!
Navigation
[0] Message Index
[*] Previous page
Go to full version
