Author Topic: What a Shame..!!  (Read 21003 times)
Offline z1100r
    • Home Pages
What a Shame..!!
« on: June 04, 2013, 11:36:04 AM »
Hello chaps,
  I was here alot a couple of years ago when I corrected a terrible dis-service I'd bestowed my poor old 500-4. I recorded its resoration on here.
I have however become one of those thats just looks in from time to time.
Well to get to the point my Mother-in-laws gardner collared me the other day and asked if would be interested in getting his old bike going - he fancies a tootle round on it again.
"Hey that 500 looks great, would you mind having a look at a bike I've got..?"
"Yeah sure.. what is it..?"
"A 400-four"
"oh right, I used to like the Yellow ones"
"It is Yellow".
"Whats up with it.??"
"Nothing its just not been run since 1981".
"Yeah Ok I'll have a look at it".
Well bugger me....it  must of been a mint bike that had only done 1,700 miles when it was parked in a shed. Its been relatively well stored, but not been turned over or even uncovered since 1981.
The good bits:-
Paint work is Excellent,
Chrome is really good,
All brackets, nuts and bolts etc still have their original plating and look new.
Master cylinder and caliper/disc look new, as does all rear brake gubbins.
Engine exterior, Dusty and grimey, but looks perfect underneath.
The bad bits:-
The brake fluid has solidified,
Clutch cable has seized solid....I mean solid, and throttle cables are stiff.
The baffle components of the immaculate original chrome silence poured out onto floor as a pile of orange powder.The bits that are left just rattle around.
Carbs slides are seized and inside the float bowls is an horible mess.
THE WORSE THING OF ALL though is that he has tried to kick it over. The inlet valves are seized/very stiff in the guides (too stiff for springs to return them), it must of started to whizz over then went clonk and locked solid.
2 bent inlet valves and 2 broken inlet valve guides, exhaust valves are fine, cylinder bores are perfect. When I eventually got the head off the inlet valves were all jammed down in the open postion.
Bottom line though is that with not too much effort this thing will look incredible for an original untouched 1979 bike. I mean fix these valves and strip the front brake stuff, buy a new clutch cable and free off the original throttle cables ( at least they move) and give ity him back to clean....wahhay. So I rang DS to enquire about parts and was surprised to find NO INLET VALVES (been on order for a year), have to order pattern Valve guides, clutch cable £25.
Hmm, need a secondhand head or just a couple of guides and valves. I used to have tons of this stuff cos i raced a Yoshi 460 but I only have 500/550 parts now - typical.
Will post some pics shortly when its been degreased and dusted off. I cant wait to have a go on it..!!
Offline PatM
Re: What a Shame..!!
« Reply #1 on: June 04, 2013, 01:46:35 PM »
Wow- Sounds like you know your stuff- What a find! Id go for an ebay head, as its just a few bits you want or someone on here might oblige. My new pipes (pattern of originals from DS) have arrived today- not bad considering I only ordered them Sunday- so I will be out dicking around doing that later on today..Have fun!- sorry, Ive got no engine bits to assist.
« Reply #2 on: June 04, 2013, 02:04:54 PM »
CMSL in Holland has genuine inlet valves in stock, 18 euros each!
Offline z1100r
    • Home Pages
« Reply #3 on: June 05, 2013, 11:41:02 AM »
I've been Saved...haha...A friend of mine just texted me from the IOM. He can sort me out a spare head as long as i fix the immobiliser/alarm on his Pan Euro as a swap. Excellent. trouble is he's not back until Saturday. I have no patience..!!! Doh. Still it gives me time to sort out the incredibly bad carbs. Petrol left in since 1981 has done them no favours. Inside of tank is probably not great either ..not looked yet.
Funny but I last rode a 400 four in the IOM. A mate lent me his customised black 1976 400four to go on in 1984. 2-4 seat, piper exhaust, fancy black paint job, I had a great time on it. I did a minimum of 2 laps a day rain or shine for a fortnight trying to learn the place. Blimey that was a long time ago.
CMSL list the valves but dont currently have any either apparently...and they only have pattern guides. Silvers told me that in a round about way. I'd rather tap some guides out of this spare head and pick the best 2 original valves from it i think. Knowing my mate this head of his will have stripped threads and be from a right old knacker. hehe. I'll salvage something I hope and retain the bikes original head.
Getting those circlips out the master cylinder is a bitch aint it...!!! haha. had to grind down my favourite long nose pliers to do it last night. Sulk.
Offline tom400f
« Reply #4 on: June 05, 2013, 03:56:33 PM »
See http://www.sohc.co.uk/index.php?topic=4812.msg22294#msg22294
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
« Reply #5 on: June 05, 2013, 04:16:31 PM »
I would use pattern guides over tapped out original ones as they do loose some metal, albeit a tiny amount, and the new ones need reaming to size whilst the new ones may end up the wrong size after fitting.
If Dave Silver sells the part they are good to use as he won't risk his reputation on crap.
Why not use the second head complete anyway?
Offline z1100r
    • Home Pages
« Reply #6 on: June 05, 2013, 06:17:43 PM »
I'll re-evaluate the situation when he gets back and I actually see the state of his secondhand head. Everything looks new on the proper head Bryan - exhaust studs etc, no broken fins, totally flat, and nice and shiny.
Sort out brakes and carbs tonight. looking forward to it.
Offline z1100r
    • Home Pages
« Reply #7 on: June 06, 2013, 07:50:46 PM »
well I did the brakes...used my old 500-4 master cylinder in the end just to get them going....his master cyl looks new on the outside but my god not on the inside..all internal parts are rotted away. Caliper perfect. Swinging bracket perfect. Brake works perfect now.
So carbs...oh my god....they look brand new on the outside aswell, all plated shiny bits, screws and carb bodies as new. An amazing looking set of carbs....inside though, deary deary me. All jets blocked solid, float bowls lined with a layer of brown and green hard laqueor with a layer of grey powder sludge on everything. All primaries blocked solid, mains blocked solid, floats dont move, slides seized - an absolute nightmare. Struggled like mad to pull the main jets out. Horrible. And the smell. Gawd...!!! Good job I had all the drill sizes for the jets.
Done most of it now....but will have to remove emulsion tubes cos I just know they are going to be horible aswell. I guess they tap out upwards - cant remember. I need main jet and float valve orings....is 4 keyster kits the only way. I only need 8 orings...!
Clutch cable arrived.....£25 seems a bit steep for a fairly simple cable, but heh ho I aint paying. Lubed the throttle cables, perfect.
Nearly ready for this dodgy secondhand head.  ;D
Offline PatM
« Reply #8 on: June 06, 2013, 08:36:58 PM »
The 400/4 tubes come out via the float chamber- usually with a bit of pressure from the main venurii from you finger! Yours  my friend, will need a darn good soaking in carb cleaner
Offline z1100r
    • Home Pages
« Reply #9 on: June 07, 2013, 03:17:51 PM »
Well after a ton of effort...carbs all done except main jet O rings...As I am always searching for tiny o rings I have bought a large selection of viton o rings between 3mm and 6mm ID of various sections from 1mm -  all less than £20. Wont be here until next week. Should have rest of bike ready by then.
Carbs came up surprisingly well, they look very good on the outside and as good as any other set I've seen on the inside.
held up camchain and kicked engine over last night until oil spewed from barrel feed holes. Didn't take long.
All looking good ....come on matey with the head (the Senior is today so he should be back tomorrow).  ;D
Offline z1100r
    • Home Pages
« Reply #10 on: June 13, 2013, 10:23:49 AM »
Back on the case..... my O-rings arrived...4mm id 1mm section seem to do the trick perfect.
My mate turned up with the head...Firstly its a black painted mess...its been 'chiselled' off its previous engine, gas flowed by an idiot, and half the exhaust studs are snapped or stripped. Oh and a Broken fin at the front...valves and guides seem good though, and not a mark on cam bearings...strange. So a quick wash down and both heads in the oven tonight for valve and guide swap.. Should be riding this by the weekend. Will knock out the broken ones first just to see what happens and how dodgy they are to do.
Must remember to take my camera in the garage tonight.
Offline z1100r
    • Home Pages
« Reply #11 on: June 16, 2013, 04:35:52 PM »
 Well valve guides were no problem...oven on 220 and tapped them out...cooled em off and bumped them back in the proper head...all done in minutes and real easy.
Bike ran like a bag of crap though. Had washed out tank and thought all would be OK. oh no it wasn't. Mesh bit had rotted away on tap and tap was blocked solid with crap. Ran bike on temporay plastic bottle for a while but still crap. Carbs off again to find nothing wrong until i happened to notice quite by accident then when blasting air line down main jet hole on 3 of the carbs air was blast out the back brass pipebut on no.2 carb nothing. Drills out again. THat fixed it. Balanced carbs and away it went, cruising down the road and sudden mega racket. The back end plate of the exhaust silencer blew apart and al the contents flew out. A few miles later and she ground to halt again due to crap comming from tank blocking tap. Shoved a cam chain and load of nuts and bolts in tank and shook it about but not much crap came out...still doesn't take much I suppose if it goes down the tap. Gotta wait for a new tap and an airfilter now.  I cant tell how its running really with that noisy noisy silencer.
By the time I've finished this thing is going to of cost a few quid.
 Battery, silencer, sprocket set, oil filter/oil, clutch cable, master cylinder kit, head off for valves etc, hours and hours on carb cleaning, airfilter, petrol tap. It has to be a labour of love dont it.
Offline z1100r
    • Home Pages
« Reply #12 on: June 18, 2013, 09:38:49 AM »
£100 for a pattern silencer from DS..mind you thats nothing compared to 900 quid odd for the original pipes holy crap.
I went up my loft to my spares supply. I knew a while ago I had bought a couple of reverse cone shortie silencers for my pair of 500 brit singles and they came with multiple collars to fit most sizes of pipe.  Cost £27 each.
Well talk about being made for the job...it looks and sounds lovely and fitted a doddle. Another £25 to this guys bill though. I'm guessing he's going to get a £300 bill for putting this thing back on the road. Does that seem reasonable considering all the work and parts, I think so. He's on a bloody cruise for his Ruby wedding so not been able to confirm the spending. I remember another of my mates mate only paying £300 for a whole running reasonble 400 four not that long ago. Oh dear. This is an exceptional specimen though. Should have a proper silencer really but he can buy and fit that himself.
Its just sitting there waiting for some more DavidSilver 'gold' to arrive at the moment. Will go up and give it a clean and have a photo shoot tonight. Its even got its original Bridgestones. Scary. Lol
Blimey the mega's have gone up.
http://britishbikebits.com/unbaffled-universal-megaton-reverse-cone-chrome-silencer-1-3-4-1-3-8-inlet
Offline tom400f
« Reply #13 on: June 18, 2013, 01:00:30 PM »
Sounds a bit like mine - it had 1,800 miles when I got it, now only 2,200...
My silencer seems OK after a long lay-up. Some bits have come out but the end plate seems sound and it seems to work. Of course may not stand up to real use as its only been started recently. Down pipes/collector could use a rechrome but sound. Everytyhing else is fine.
I also have original tyres (not fitted!)
1978 CB400F2 Yellow
Offline z1100r
    • Home Pages
« Reply #14 on: June 18, 2013, 02:44:11 PM »
Tom,
     Sounds very similar. On this one the header pipes are mint, actually look brand new. The silencer though showed bulging on the outside where the baffling was spot welded in. The first thing that happened was a large hole appeared in the recessed back bit next to the exit hole. The insides had allready well rusted and collapsed - you could here them rattling about, and exhaust was noisy. I was giving the bike a bit of a gunning when the sound levels rose to unbearable and the whole lot disintegrated.
     Wheel rims are good, spokes are average, chainguard is mint, all handlebar controls, headlight etc mint, mudguards very good - not polished them up yet to see just how good. Paintwork could be new, not even a scratch. Engine paint not as good as I first thought. All ancillary components and brackets really good and everything comes undone no problem.
    I cant remember how fast these things go, speedo said 90mph upright against wind and it seemed about right. Took a while to get there though. Acceleration is tame and requires lots of revving. Tootling about upto 60/70mph is absolutely lovely (I must be getting old). I'm 5'11 but I still find it quite comfortable - especially compared to my Thunderace.
    I do have a soft spot for these SOHC bikes, I raced a 550 and won a club championship on it, my mates had them as road bikes and they were all thrashed to absolute near death racing RD's but unlike the RD's -  no blow ups that I can remember. They were 460'd,  yoshimura'd, piper'd and ace bar'd. fancy seats , crappy paint jobs, culminating in total abuse. I bet most of them would still go with a little tlc. lol
Looking forward to a quieter less eventful ride in a few days. No more 'carb tuning' required I hope, it should be back to how it should be. A smooth quiet pleasing little thing.
I wont want to give it back.....he wont use it...I bet its on Ebay in a few weeks.
« Last Edit: June 18, 2013, 02:46:39 PM by z1100r »
