Author Topic: seat tail piece trim  (Read 4668 times)
Offline neat street
« on: July 02, 2013, 06:30:24 PM »
Hi, Firstly, thanku for all the help given so far on my CB750F1 build, I know I will need allot more help in the near future, but I am now after the plastic chrome trim that goes around the tailpiece. does anyone know where this can be brought from? I have the metal clips, but the plastic has a crack and the spare has lost its zing
John
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Re: seat tail piece trim
« Reply #1 on: July 03, 2013, 07:18:15 AM »
You need to search one of the one line parts lists for the part number then see if a supplier has it lis Dave Silver or CMSNL
Offline Waggles
« Reply #2 on: July 03, 2013, 07:55:41 AM »
Think you may have to restore its Zing! Not sure whether you mean the long strip under the seat / tail unit or the one around the rear light? doesn't make a lot of difference tho as I am afraid a lot of F1 specific parts are no longer available, those trim strips included according to CMSNL. I also found the chrome grabrail under the seat to be unobtainium too.
My only suggestion is to look around auto restorers ( Like Frosts perhaps? ) who may have some generic strip that is similar and could be used. If all else fails I am sure you could find some edge strip to cover the raw edge.
« Reply #3 on: July 03, 2013, 08:11:35 AM »
If Waggles is correct, and i have no reason to doubt him, try the old Mini chrome plastic edging trim from the welded seams, used to buy it in rolls but immers in as water as hot as you can take to get it flexible enough
Offline neat street
« Reply #4 on: July 03, 2013, 07:08:33 PM »
Thanks all, it was the trim on the tail around the rear light, I will try and play the cracked one first and see what result I get before I go onto the `lost zing one`
Many thanks for your help
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
Offline Waggles
« Reply #5 on: July 04, 2013, 07:27:40 AM »
Good luck. That particular trim being plain 'chrome' would be a prime candidate for replacement by the old mini plastic strip Bryan suggested. It may be a bit wide but with a bit of trimming should do the job
« Reply #6 on: July 04, 2013, 07:39:53 AM »
Online mickwinf
« Reply #7 on: July 04, 2013, 07:24:45 PM »
also look at windscreen trim for fairings, available in smaller lengths I used it for my tank edge.
