CB750
Wiring Loom question ??
Topic: Wiring Loom question ?? (Read 7052 times)
cb750stu
SOHC Expert
July 08, 2013, 01:19:32 AM »
Hi Folks i need to extend quite a bit of my wiring loom so i can fit all my electrical bits under my cafe seat,
I am away to order some different colour wire so what size and what amps do i need ie 15 amps 27 amps etc
Regards
1976 CB750 F1 SS in bits !!! but getting there
Re: Wiring Loom question ??
July 08, 2013, 08:59:05 AM »
If yoou want to move the parts a long way you need to overspec the wiring size to stop voltage drops due to length especially on any wiring to battery or rectifier
cb750stu
SOHC Expert
July 08, 2013, 05:36:06 PM »
There not getting moved far just from standard position to under the seat maybe 10 " !!!!
July 08, 2013, 06:24:48 PM »
Thats a long way in volt drop language mate
cb750stu
SOHC Expert
July 08, 2013, 08:40:03 PM »
Really ??
Any suggestions on what i should go for ??
Not much of a electrical guru im afraid,
July 09, 2013, 08:27:21 AM »
Not sure what the original wire cross section size is but I would at least double it for that distance, and solder any connectors
LesterPiglet
1977 CB550F2
July 09, 2013, 07:17:44 PM »
You can use a smaller guage wire these days compared to what was available in the 70's. I did a bit of research last year and promptly lost all my links.
Lobo
Lobo
Lobo
July 09, 2013, 11:24:06 PM »
(For the 400F).... OEM Wiring is generally 30/0.2 strand PVC coloured cable. Modern vehicle wiring is thin wall 32/.2 (2mm 16.5A) strand hard PVC for better abrasion resistance, higher current rating, higher operating temperature and lighter weight (but not quite as flexible).
(the above words shamelessly copied from a very professional 400F rebuild blog)
(Me speaking...). The above 16.5A suggestion should be plenty for the typical loads on an old CB750 - assuming you're not loading it up with triple headlamps etc - 16.5A would be good for approaching 200W of power - (ie more than your alternator output) - a single headlamp is typically 65W)
To get a working idea of wire rating simply sum the watts through your circuit, and divide by the voltage (12V) to get the current rating.... eg head + tail + stop + indicators might be 65W+5W+20W + 36W= 126Watts... /12 = just over 10Amps. (15A wiring good here)
Suggest you include a fuse, with a value (obviously) less than the wire amp rating.
And check your alternator output as I think it may be I the region of 13A (156W) - don't overload it!
http://www.autoelectricsupplies.co.uk/category/10
Cheers,
Lobo
Last Edit: July 09, 2013, 11:32:54 PM by Lobo
LesterPiglet
1977 CB550F2
July 09, 2013, 11:43:08 PM »
I'm useless with electrickery so I just chose a wire that had a rating a bit higher than the fuses in the bike.
Green1
July 09, 2013, 11:55:48 PM »
Your not the only one Lester I managed to blow the electric meter of the wall changing the living room lights
Don,t ask me what I did I still don,t know
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
cb750stu
SOHC Expert
Reply #10 on:
July 10, 2013, 12:00:56 AM »
Cheers Folks for the answers !!!
Im not going to be running indicators or electric start so im not really doing much to the loom apart from not using a few bits and just making a few bits longer to reach under the seat,im not really looking forward to the wiring part at all im hopeless with diagrams etc i might have to get my Dad up to help hes good with that kind of stuff.
Thanks again
Stuart
PS If im not using the indicator wires etc do i just blank them off or cut them back ??
LesterPiglet
1977 CB550F2
Reply #11 on:
July 10, 2013, 12:11:17 AM »
I would leave them in case you change your mind in the future.
cb750stu
SOHC Expert
Reply #12 on:
July 10, 2013, 12:26:38 AM »
Good point Lester ill keep them !!!
CB750
