CB350/400
Setting Ignition Timing With a Strobe Light
Topic: Setting Ignition Timing With a Strobe Light (Read 13406 times)
Lynx
Repair & Despair Under One Roof
SOHC Expert
August 29, 2013, 03:40:29 PM »
Hi guys,
Today's question is when using a strobe light, what revs and timing marks should I use.
Regards
Steve
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Lobo
Lobo
Lobo
Re: Setting Ignition Timing With a Strobe Light
August 30, 2013, 02:05:27 AM »
From a 400F maintenance manual.
Hope it helps,
Simon
August 30, 2013, 08:45:23 AM »
A strobe IS ONLY USED for checking the advance mechanism NOT for setting the timing
Piki
SOHC Expert
August 30, 2013, 08:49:39 AM »
STROBE is good for checking the advance and for "FIRE TIME" adjust, you can do both, "Timming and Advance".
Best Regards.
Lynx
SOHC Expert
August 30, 2013, 10:05:17 AM »
Thanks for the instructions.
I always though setting with a strobe was MORE accurate than setting static as it is more real world, setting on a running engine. You can see when the spark plug actually gets the signal.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Piki
SOHC Expert
August 30, 2013, 10:19:15 AM »
Yes, I just upload one PDF about it, look my last post!!!
Sorry for my English.
Lynx
SOHC Expert
August 30, 2013, 11:57:02 AM »
Hi Piki,
Where is the PDF?
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Piki
SOHC Expert
August 30, 2013, 01:10:16 PM »
Is a Post called HONDA FOUR SERVICE in MISC/OPEN.
Bitsa (Ralph Wright - RIP)
August 30, 2013, 07:35:40 PM »
Bryan,
If like me you in previous years attended a Honda course was your course different to mine.The Honda training guys showed us on the course that using a strobe light was the best way of doing it For all Honda bikes so I don't know where you get your ideas from can you explain more for me as I am trying to remember all I was taught?I know about the dwell etc but for years have I practiced something the manufacture taught me and now is wrong.
Bitsa
August 30, 2013, 08:53:49 PM »
I did the training in the 70's and was told to set the gap with feelers, the timing static with a bulb and then check the advancer with a strobe BUT you had to be good with feelers to get the gap right (and have a set with a 14thou one!) have patience and practice to get gap and timing right at the same time and to be honest unless a problem was reported by the customer rarely bothered to use a strobe as it took too long to set up the Honda box!--likewise the dwell box
i always found that the advancer started opening very early so using a strobe set the timing advanced but still in the marks on full advance.
You have to remember I was apprenticed in 69 and brought up on old Fords to the extent that i proved to an apprentice in the 80's who tried to tell me it was impossible to set points and timing without a dwell box and a strobe that i could do an essex v6 (capri 3.0) in half the time it took him and get better results.
A dwell box and strobe may well be easier for someone who does not do the job often but seems like witchcraft to this old timer mate
Piki
SOHC Expert
Reply #10 on:
August 30, 2013, 09:09:21 PM »
I have the "Honda Box" and 10 Minute is enought for a Perfect Tune-up.
fisjon
Newbie
Reply #11 on:
September 29, 2013, 07:41:41 PM »
I used to find that my CB750 K1 was a bugger to time up.
The only way I could get the ignition timing spot on was to set different points gap !
I even bought several point sets but to no avail, they always had to be set different.
I found out later that the gap is not as important as the dwell and if you did not get the timing right the pipes would go blue very quick.
I have a dwell meter and a strobe with a power source and after setting/checking the gap I alter it to get the correct dwell then adjust the timing regardless of the gap. If the dwell is correct you will always get a fatter spark.
Dwell more important than gap! But if you fit Boyer electronic you would think you were riding a more powerful bike.
CB350/400
