Author Topic: Primary Chain Wear  (Read 9085 times)
Offline cinqmars2
  • Learning on the job.
Primary Chain Wear
« on: September 24, 2013, 04:29:41 PM »
So I've got to dismantling my engine and I've found some horrendous gouges in the lower case. The primary chain had been running very loose for a long time. I've never had this running so couldn't say how loud it would have been!
Of course I'll be getting a new primary chain, but what do I do about the case? The cut to the oil passage is super deep (although not through yet) should I get it filled in? I was considering using an epoxy putty, would that hold up inside an engine?
Sorry for lack of a photo will try and get one up soon.
Thanks!
Re: Primary Chain Wear
« Reply #1 on: September 24, 2013, 04:55:41 PM »
I really wouldn't worry too much about as it hasn't broken through, I certainly think it would be a bad idea to put epoxy putty or any similar substance inside an engine, too much risk of it degrading, breaking up and causing untold damage by blocking the oil pump strainer :o If you are REALLY worried about it, you should find a reputable alloy welding company and get them to do something with it, but even that is not without risks :-\. It's your engine after all, but if it isn't leaking I would leave well alone! ;D
Offline cinqmars2
« Reply #2 on: September 24, 2013, 09:46:01 PM »
Ah ace! I may well take you up on that offer, I have removed the bearing on the clutch side but I daren't risk trying to get the other out in case I knocked it sideways and warp the case, is there any risk of this?
I'll get a quote from a welding company and it it's ridiculous I'll forget it.
Thanks for the help as always!
Online Bryanj
« Reply #3 on: September 25, 2013, 07:48:48 AM »
How much for a set of rubbers  mate
Offline cinqmars2
« Reply #4 on: September 25, 2013, 11:28:25 AM »
I would take you up on that offer but happy to let BryanJ have them if he's in need, I'm a while away from reassembly and don't get paid until this Friday so can't do much about it right now, are they hard to come across?
Offline cinqmars2
« Reply #5 on: September 25, 2013, 04:13:48 PM »
Deal! I'm all for supporting the cause. I'll PM you now.
Online Bryanj
« Reply #6 on: September 26, 2013, 07:28:43 AM »
Oddjob, pm me your paypal and i will have the rubbers for the next rebuild, I already have chains sent from Australia a few years back
Offline cinqmars2
« Reply #7 on: September 26, 2013, 10:44:14 AM »
BryanJ, do you have a spare primary? They seem to be a little on the steep side over at DavidSilver...
Offline cinqmars2
« Reply #8 on: September 26, 2013, 01:57:22 PM »
Is it new?
Offline cinqmars2
« Reply #9 on: September 26, 2013, 02:15:08 PM »
You're sorting me right out!  ;)
Offline LesterPiglet
  • 1977 CB550F2
« Reply #10 on: September 26, 2013, 10:50:14 PM »
If you come across any more sources for a primary please let me know. I've never been happy with the amount of noise mine makes and it would be good to have the option to replace it on a whim.  :) I must also buy those dampers. I didn't know they existed.
  • 1977 CB550F2
« Reply #11 on: September 28, 2013, 12:06:39 AM »
Thanks Ken.
