Author Topic: Lifting the bike - no centre stand  (Read 9989 times)
Offline hunterso
« on: October 04, 2013, 02:05:11 PM »
Just got round to thinking i would like to be able to raise my bike to get the back wheel off at some point.
Going to prove fairly difficult without a centre stand.
Whats the favourite method  - paddock stand or some kind of lift under the engine?
Offline LesterPiglet
  • 1977 CB550F2
Re: Lifting the bike - no centre stand
« Reply #1 on: October 04, 2013, 09:50:36 PM »
I just use a hydraulic jack and some wood made to fit the contours of the underside of the bike. I've never had a CS and never thought, "a cs would be handy now".
In the future I'm sure I'll have some sort of fancy device but I don't need it yet.
Offline Green1
« Reply #2 on: October 04, 2013, 10:20:54 PM »
My Honda's are the only bikes I own with a main stand and I love it but I still use a front stand when messing around with the front end.I use front and rear paddock stands on the other bike for all most all servicing and cleaning it's amazing how much you miss when the bike leans to the left.With out them even minor things like checking the chain and oil level is a pain in the ass.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
  • 1977 CB550F2
« Reply #3 on: October 04, 2013, 10:36:04 PM »
No problems checking the oil in my bike.
Levels and chain tension are ideally checked with both wheels on the ground with rider bum on seat.
Offline Green1
« Reply #4 on: October 04, 2013, 10:49:13 PM »
My Triumph is a nightmare without the paddock stand because the dip stick is so low down and you have to screw it in all the way to get a reading.
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
  • 1977 CB550F2
« Reply #5 on: October 04, 2013, 10:59:33 PM »
Don't you have a manservant?  :o
My goodness, I couldn't be without mine.  :P
Offline Green1
« Reply #6 on: October 04, 2013, 11:08:43 PM »
He's not talking to me since I took over his garage and through his car on the drive ;D
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline matthewmosse
« Reply #7 on: October 05, 2013, 07:31:59 PM »
Chain hoist suspended from garage roof, and baler twine around either the headstock or rear shocks depending on which end needs work. I have a paddock stand that was left in the in laws shed by powhen they moved in, worth about what I paid for it - ok for light jobs but it bends and drops my 125 even.
Offline hunterso
« Reply #8 on: October 06, 2013, 04:04:32 PM »
I was thinking of a paddock stand but dont like the idea of having to stand behind the bike to steady it while you hoist it up.
Have also been looking at this kind of thing - which seems quite handy
« Last Edit: January 13, 2014, 01:02:40 PM by hunterso »
  • 1977 CB550F2
« Reply #9 on: October 07, 2013, 02:51:50 AM »
The above is basically what I have cobbled together.
Offline busa
  • busa
« Reply #10 on: October 07, 2013, 11:26:39 PM »
I use the same as this one above.  and have no problems with it  with my 550 k3,  I also used it for my modern race bikes  for wheel changes  fork works etc.   they are stable  and also have tie down points  as well just for the added security. would recommend it  even with motor in or out  is fine
Offline hunterso
« Reply #11 on: October 08, 2013, 11:19:52 AM »
The only problem i can see with the above is that my exhaust runs under the bike so hides the frame rail on one side.
Is it ok to lift the bike with wood packing underneath the engine?
  • 1977 CB550F2
« Reply #12 on: October 08, 2013, 02:10:01 PM »
That's what I have been doing.
Offline bomber
« Reply #13 on: November 08, 2013, 10:13:52 AM »
I had same problem,
My solution to lift the front was a friend who whelped with lifting and couple of stands.
I was a bit concerned but it was sturdy enough to take the forks of and bike was left like that for a week or so. It didn't wobble of slip.
I had stands resting on the frame.
Ignore that jack in the background, I didn't use it at the end.
Hope that helps
One step forward, two steps backward...
Honda CB550F 1976
