Author Topic: which ring goes on top ?  (Read 4833 times)
Offline billy192
    • Shermonkel
« on: October 04, 2013, 03:27:23 PM »
Just putting the new rings on the new pistons, one ring has a bevel on top
the other no bevel
which is the top ring?
Billy
Billy
ka-ja
Re: which ring goes on top ?
« Reply #1 on: October 04, 2013, 04:44:01 PM »
Hi,
      I think the ring with the chamfer is the top ring, the chamfer is intended to help after a re-ring on a used bore, it minimises the effect of any wear ridge around the top of the cylinder wall from the old piston
« Reply #2 on: October 04, 2013, 06:19:28 PM »
Champher hasno bearing on it,
chrome ring top groove black ring secong groove
numbers facing upwards
Offline billy192
    • Shermonkel
« Reply #3 on: October 04, 2013, 07:35:34 PM »
They are both black?
Billy
ka-ja
« Reply #4 on: October 04, 2013, 07:42:59 PM »
Hi,
    Apologies to billy192 and bryanj, I can only go with my remembered instructions for my yoshimura rings, which were all black finihed, and were fitted as stated, there was a dot to mark comp. ring upper side
« Reply #5 on: October 04, 2013, 08:22:25 PM »
Billy,
Hoped you remembered to check the ring gaps don't assume cos its new its all OK.
Bitsa
Offline billy192
    • Shermonkel
« Reply #6 on: October 04, 2013, 08:43:49 PM »
bitsa,
will check first thing in the morn before fitting barrels
Billy  :P
Billy
Offline billy192
    • Shermonkel
« Reply #7 on: October 05, 2013, 09:19:55 PM »
thanks
 8) 8) 8)
Billy
