Author Topic: Engine Removal / Intallation Easy Method  (Read 7946 times)
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
« on: November 03, 2013, 12:18:37 PM »
This is installing the engine on a CB500/4 , removal is just the reverse procedure. Same procedure can be used on the 400, 650 and 750
1. Remove sump, oil strainer, oil filter housing, breather cover and exhaust studs from the engine (photo 1)
2. Sit the engine on its side , kickstart side down . This is imporatnt it doesn't work as well if the engine is the other way up. (photo 2)
3. Lower the frame over the engine and install the two lower engine bolts (photos 2 & 3)
4. Have some blocks of wood in place to roll the frame / engine aassembly onto in upright position. The wooden blocks should be positioned to avoid the side stand bracket (photos 4 & 5)
You might want to protect the frame's paintwork by wrapping it in bubble wrap or similar before you start
« Last Edit: April 23, 2017, 11:08:43 AM by Ewan 500 K1 »
500K1 basket case for later
Offline Ewan 500 K1
Re: Engine Removal / Intallation Easy Method
« Reply #1 on: November 03, 2013, 12:24:54 PM »
seems to be a fault on the forum thats causing pictures to not appear just now !
Offline AndyH
  • I'm privileged to be a
« Reply #2 on: April 23, 2017, 10:41:54 AM »
....and 3.5yrs later, still no pics.   I, for one, would be interested in seeing the pics in all their naked glory!  ;D
Andy
1971 CB750K1
1972 CB500 Four K1 (SOLD)
1978 Suzuki GS750E
Previously....
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #3 on: April 23, 2017, 10:51:54 AM »
There are quite a few vid's on Youtube showing how (and how not!!) to remove engine by laying bike on it's side. Probably find more under CB750 than 500/550's
« Reply #4 on: April 23, 2017, 11:02:55 AM »
Too much like hard work, lifting a bike up like its fallen over.  I'll stick to my way
Offline Ewan 500 K1
« Reply #5 on: April 23, 2017, 11:07:01 AM »
so, 3 and a half years later ....
(Attachment Link)
2. Sit the engine on its side , kickstart side down . This is important it doesn't work as well if the engine is the other way up. (photo 2)
(Attachment Link)
(Attachment Link) (Attachment Link)
4. Have some blocks of wood in place to roll the frame / engine aassembly onto in upright position. The wooden blocks should be positioned to avoid the side stand bracket (photos 4 & 5) (Attachment Link) (Attachment Link)
« Last Edit: April 23, 2017, 11:09:30 AM by Ewan 500 K1 »
« Reply #6 on: April 23, 2017, 11:07:36 AM »
Your way is very good as well Mike, especially if there is only one person doing it.
