SOHC.co.uk Forums > CB350/400
Speedo Wobble
<< < (2/2)
kent400:
Check the speedo cable, if there is any damage to the cable outer covering water can enter and corrode the inner cable. That causes the inner cable to be less flexable and as a consequence slows down, and speeds up as it revolves.Probably gets worse the faster the cable revolves. If there was a problem with the speedo the needle would waver at speeds a lot lower that 50 mph.
Sharpy:
Brand new cable, however I will not write that off as the bike has been sat for a while in-between me getting the cable and getting it on the road so it may have gummed up quite a bit, they are cheap enough so I might just get another.
UK Pete:
Hi if you mean the speedo needle pointer is jumping about rather than going up and down smoothly then it means your speedo damper pot is dry and needs refilling
pete
Sharpy:
Ah okay, thanks Pete I will check that out as well... The list of things to do over winter is getting longer, and thats just for the speedo!!!
Bitsa (Ralph Wright - RIP):
Plus one with Pete have finally got a good one now.
Bitsa
Navigation
[0] Message Index
[*] Previous page
Go to full version
