Author Topic: Broken tappet  (Read 26506 times)
Re: Broken tappet
« Reply #45 on: February 28, 2014, 10:48:58 PM »
Offline bomber
Re: Broken tappet
« Reply #46 on: February 28, 2014, 11:06:09 PM »
Thanks, although I was hoping for it to be cheeper than DS, in stead is 5er more...
http://www.ebay.co.uk/itm/171231649452?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Found one. For a sealer i use Hondabond HT.
One step forward, two steps backward...
Honda CB550F 1976
Re: Broken tappet
« Reply #47 on: February 28, 2014, 11:15:31 PM »
Top end gasket set is cheaper. Not sure how far you are going to go on the engine. Gasket sets from Poland are a lot cheaper. Depends on what make you think is good. I have fitted cheap head gaskets before which have blown after 3 months. OEM head gaskets are one of the best but, then you have to buy the rest.
Offline bomber
Re: Broken tappet
« Reply #49 on: February 28, 2014, 11:40:57 PM »
I'm hoping that I will not need to work on the bottom end...
I'm a bit flustered as every little thing I do seems to have make more trouble, I'm simply trying to work out how to save few quid and since I need few other bits it makes more sense to get it form DS and save 5 or 10 pounds on postage.
I can't work out if set form DS has same items as the one you kindly sent me link to.
Honda CB550F 1976
