SOHC.co.uk Forums > CB500/550
Broken tappet
Trigger:
http://www.ebay.co.uk/itm/171231649452?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Found one. For a sealer i use Hondabond HT.
bomber:
Thanks, although I was hoping for it to be cheeper than DS, in stead is 5er more...
--- Quote from: trigger6969 on February 28, 2014, 10:48:58 PM ---http://www.ebay.co.uk/itm/171231649452?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
--- End quote ---
Trigger:
Top end gasket set is cheaper. Not sure how far you are going to go on the engine. Gasket sets from Poland are a lot cheaper. Depends on what make you think is good. I have fitted cheap head gaskets before which have blown after 3 months. OEM head gaskets are one of the best but, then you have to buy the rest.
Trigger:
http://www.ebay.co.uk/itm/KR-Motorcycle-gasket-set-TOP-END-for-HONDA-CB-550-K-Four-75-00-new-/171142147373?pt=Motorcycles_Parts_Accessories&hash=item27d8dded2d
There you go £26. Good luck
bomber:
I'm hoping that I will not need to work on the bottom end...
I'm a bit flustered as every little thing I do seems to have make more trouble, I'm simply trying to work out how to save few quid and since I need few other bits it makes more sense to get it form DS and save 5 or 10 pounds on postage.
I can't work out if set form DS has same items as the one you kindly sent me link to.
Navigation
[0] Message Index
[*] Previous page
Go to full version
