Author Topic: hello every body  (Read 5749 times)
Offline tarmac
hello every body
« on: January 26, 2014, 07:09:50 PM »
hi everybody,..my name is Terry and i am the owner of a 1978 cb750 sohc,
I have been a member of the forum for a couple of years now but have never posted, so this is my first
I am doing some restoration[ repair] work and need some advice,??...the generator cover has been damaged and welded up,it looks ok but I am not happywithit and want to replace it with a good one,....there is one on ebay but it is from a K2, the question is,
will it fit a f2 crankcase or will I need one from F2 .
                                                 cheers Terry
ride safely,have a nice day
Re: hello every body
« Reply #1 on: January 26, 2014, 07:15:23 PM »
Hi and welcome.I think and I am sure if I am wrong there will be more respones after this .The only difference I know off is the f2 if memory serves me right its black.
All the best and show some photos we love photos
Bitsa
Offline tarmac
« Reply #2 on: January 26, 2014, 07:22:44 PM »
hi bitsa,..
i tried putting up some pics of some carb balancing I was doing but I had no joy.
 the pics are on the desktop and appeared to be accepted but wouldn't load.
     terry
« Reply #3 on: January 26, 2014, 07:36:14 PM »
Tarmac,
Hope your call sign is not because you hit the tarmac regular as for pics after you attach them the screen might go blank press f5 to refresh then go back on to the site as usual they should appear unless there too big as Steve has advised.Works for me that way
Bitsa
Offline tarmac
« Reply #4 on: January 26, 2014, 07:38:15 PM »
   here are a couple from photobucket
« Last Edit: January 26, 2014, 08:32:19 PM by SteveD CB500F »
« Reply #5 on: January 26, 2014, 07:46:08 PM »
Apart from the flash they look good enough to me Tarmac
Bitsa
Offline tarmac
« Reply #6 on: January 26, 2014, 07:47:07 PM »
Bitsa,... not only did I hit the tarmac regular,i also went through a few hawthorn hedges during my ill spent youth,
but not only did I slide very well I got quite good at it. :)
     regards terry
« Reply #7 on: January 26, 2014, 07:51:37 PM »
Yeah me too, the best one too fast on a bend hit a del boy motor cut it in half and the guy in it was rolling a fag and sh t himself.
Bitsa
« Reply #8 on: January 26, 2014, 08:33:39 PM »
When you are linking to Photobucket, you need to copy the text in the "Direct" box and place it between the image tags.
I've fixed the two below for you.
Steve
Offline tarmac
« Reply #9 on: January 26, 2014, 08:46:24 PM »
thanks Steve,..that's just how i hoped they would turn out,
                        cheers Terry
Offline tarmac
« Reply #10 on: February 01, 2014, 07:33:35 PM »
Bitsa,...got some news for you!!...went ahead and bought the Generator cover from ebay and got it yesterday.
and there appears to be no difference between  both of them, even the part number,...as there isn't a part number??.
that does not make sense,but could'nt find one!!
any way when the weather improves i'll get around to fitting it proper as at the moment I have only offered it up for comparison.
                                                         cheers, terry
« Reply #11 on: February 01, 2014, 07:37:09 PM »
Nice one and there is a part number will let you know later.
All the best
Bitsa
« Reply #12 on: February 01, 2014, 07:48:38 PM »
Tarmac,
Makes me giggle your name all the time.All K,s are 11631 300 010  F2 is 11631 410 010 cos its black
Bitsa
Offline tarmac
« Reply #13 on: February 01, 2014, 08:19:32 PM »
much appreciated,..thank you,
                                             terry
« Reply #14 on: February 01, 2014, 08:47:41 PM »
Hi and welcome from Ashimoto
I bought a NOS F2 one a couple of years ago and after stripping the black paint off it (not even anodised) it fits my K0 fine and only subtle differences so you should be fine.
cheers AshD
