550 k3 tank
3
Topic: 550 k3 tank (Read 14082 times)
Trigger
Re: 550 k3 tank
Reply #15 on:
March 27, 2014, 10:46:13 PM »
The cheapest way is find a nice gravel drive way at 3am, and take a couple of kilo. Make sure you have the tap removed and cap that off. Put the gravel in the tank and wrap it in a blanket. Next line your tumble dryer with another blanket and put the tank in. Pack the dryer out with more blankets, so that the tank can't move and switch it on for 10 to 15 minutes.
Once the gravel has gone its job. Empty out and flush with water. It doesn't get any cheaper than that.
LesterPiglet
1977 CB550F2
Re: 550 k3 tank
Reply #16 on:
March 27, 2014, 11:06:51 PM »
I filled mine with water and soap powder. Can't remember if it was Surf or Daz though.
Works on light rusting. Lots of powder.
Trigger
Re: 550 k3 tank
Reply #17 on:
March 27, 2014, 11:10:20 PM »
That's more expensive Les
LesterPiglet
1977 CB550F2
Re: 550 k3 tank
Reply #18 on:
March 28, 2014, 05:08:33 PM »
Yes but it smells lovely after.
MikeM
SOHC Expert
Re: 550 k3 tank
Reply #19 on:
March 30, 2014, 02:09:33 PM »
giving it a wash then as above
is there no filter in these bikes ?
undone the petrol tap and nothing in it?
looks like I need a new seal round the tap but was expecting some sort of gauze?
LesterPiglet
1977 CB550F2
Re: 550 k3 tank
Reply #20 on:
March 30, 2014, 04:29:48 PM »
I'd expect to see this on the tap.
Isn't yours a gauze?
Trigger
Re: 550 k3 tank
Reply #21 on:
March 30, 2014, 07:21:46 PM »
No gauze on a single out let tap.
LesterPiglet
1977 CB550F2
Re: 550 k3 tank
Reply #22 on:
March 30, 2014, 09:07:42 PM »
I beg to differ. Mine definately does.
The picture above and below is what is on mine. It's not just a tube.
Last Edit: March 30, 2014, 09:17:47 PM by LesterPiglet
matthewmosse
Re: 550 k3 tank
Reply #23 on:
March 30, 2014, 09:11:48 PM »
Gauze on the k3 tank I recently failed to sell on ebay too, I could check - I suspect the other k3 tank in the shed also sports a gauze, though it is an age since I looked.
tom400f
Re: 550 k3 tank
Reply #24 on:
March 30, 2014, 09:35:34 PM »
When I took the tap off my 400F tank I found the gauze was splitting along the "seam". May be in this case it's become detached altogether.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
mickwinf
Re: 550 k3 tank
Reply #25 on:
March 30, 2014, 09:48:48 PM »
could still be stuck in the tank?
Trigger
Re: 550 k3 tank
Reply #26 on:
March 30, 2014, 10:14:19 PM »
It is official known as a strainer. On the two out let tap you have a gauze in the tap and a strainer over the fuel straw. On the single outlet fuel tap it only has a strainer.
Could be still in the tank as mick said, or someone removed it before.
Last Edit: March 30, 2014, 10:22:44 PM by trigger6969
LesterPiglet
1977 CB550F2
Re: 550 k3 tank
Reply #27 on:
March 30, 2014, 10:23:39 PM »
Sorry If I misled anyone. I have a strainer in my kitchen cupboard.
MikeM
SOHC Expert
Re: 550 k3 tank
Reply #28 on:
March 30, 2014, 11:14:37 PM »
is this gauze meant to be inside the tube, nothing in there
could I not just put in a inline fuel filter between tank and carbs ?
there is some tiny bits of rust still in tank but a lot fell out while washing
LesterPiglet
1977 CB550F2
Re: 550 k3 tank
Reply #29 on:
March 30, 2014, 11:40:09 PM »
If that white piece you have is just a plastic tube then the "strainer" is missing.
The strainer is the white part you see in the two pictures I posted.
3
550 k3 tank
