General > New Member Introductions
New member Derby
<< < (3/3)
mick:
Hello Mark and welcome to the forum  ;), post some photos of your progress when you get chance  ;) cheers Mick
UK Pete:
Hi Mark welcome to the forum, lots of 750 owners on here so if you get stuck with anything there will be helpful advise to hand
pete
MarkCR750:
--- Quote from: mick on February 01, 2014, 08:07:51 AM ---Hello Mark and welcome to the forum  ;), post some photos of your progress when you get chance  ;) cheers Mick
--- End quote ---
Thanks Mick, will do in a few weeks , not much to see at present, engine in, oil tank in (used the original oil tank mounted transversely, looks quite convincing as a period part but I will fit a CR replica when funds allow), I have the fuel tank and seat unit but not fitted yet cheers Mark.
MarkCR750:
--- Quote from: UK Pete on February 01, 2014, 11:02:11 AM ---Hi Mark welcome to the forum, lots of 750 owners on here so if you get stuck with anything there will be helpful advise to hand
pete
--- End quote ---
Cheers Pete, just got stuck for the first time actually!, I plumbed in the oil tank, re-fitted carbs and exhaust, slaved a battery and original fuel tank today and went for a start......but it didn't !, getting a spark but the plugs don't seem to be getting wet so I suspect it's a fuelling issue, last time I started the engine was 5 months ago and I didn't re-clean the carb internals before re-fitting the carbs today  ::), now run out of time/daylight/skill so it will have to be tomorrow now.
MarkCR750:
Up and running now, I hadn't appreciated how much it needed the airbox fitted to start!, I will be re-jetting for velocity stacks soon so if anyone needs a K7 airbox let me know. Off out on XJR now to celebrate  ;D
Navigation
[0] Message Index
[*] Previous page
Go to full version
