SOHC.co.uk Forums > CB750
Dresda Honda CB750 (Identification needed)
<< < (6/9) > >>
Eric Frith:
I looked up some Laverda wheels and they are very similar, I'll do some further digging..
SteveD CB500K0:
--- Quote from: rs_pete on March 11, 2014, 01:14:57 PM ---
What is the story on the engine front alluded to in the caption?
--- End quote ---
Just that - "we understand that..."
I never met the previous owner but that is (apparently) what he told Eamon.
Steve
Eric Frith:
I've just had a look at the wheels and I would say that they are both definitely fronts, front discs are spaced to match the discs, rear disc has a separate carrier with the required bolt pattern, Sprocket carrier must have been a two piece aluminium item with the larger of the two being missing, the carrier didn't have any bearings in it and just sat on two nylon sleeves that in turn sat on the spindle. ( It's a guess as it's not there)
Eric Frith:
As can be seen here
rs_pete:
Laverda wheels from workshop manual.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
