SOHC.co.uk Forums > CB750
Cb750 k3 headlamp and ring mount wanted
<< < (3/3)
hairygit:
Be careful buying headlight units from abroad, don't forget they drive on the wrong side of the road, so the headlight dips to the RIGHT instead of the left as UK vehicles do, and will FAIL the M.O.T, so check which market it is for before wasting your hard earned cash!:))
Sent from my GT-S5839i using Tapatalk 2
Bitsa (Ralph Wright - RIP):
Yes.
Most views are correct the only difference instaed off the adjusting screw being on the left,right is the same if you are lucky enough to get either, all you have do to do is drill a hole the opposite side for you no big deal.Original stuff as we all know has worst odds than the lotto,so get with it grab it b4 you lose out if you want original
Bitsa
JamesH:
Thanks Bitsa - pulled the trigger on it and like you say I should be able to modify the adjuster mechanism if necessary. Thanks for the steer oddjob. James
hairygit:
I'm sure you'll find it's more than just the adjusting screw, the fluting on the glass is what determines which way the lamp dips, the only way round it is to stick black tape over certain areas of the lens (ask Steve D, he has to do it with his!) and if an original look is what you want, black tape will just not look right!:-\
JamesH:
Fair point - maybe i'll just move to france ;-)
Navigation
[0] Message Index
[*] Previous page
Go to full version
