Author Topic: CB500K REAR WHEEL - EQUIVALENT?  (Read 15608 times)
Re: CB500K REAR WHEEL - EQUIVALENT?
« Reply #15 on: February 14, 2014, 11:09:36 AM »
Testing picture uploads
Looks like the server is out of disc space...
« Last Edit: February 14, 2014, 11:11:57 AM by SteveD CB500F »
« Reply #16 on: February 14, 2014, 11:58:45 AM »
Yep.
2.5Gb of error logs...     Doh...    :-[
Fixed now.
Steve
« Reply #17 on: February 14, 2014, 12:10:40 PM »
Why do people have trouble with lacing. The rear is so easy, use the swinging arm as a stand. That is where the wheel will be going in the end.
I have just looked through You Tube, Vids and Oakys Garage M/C lacing is about the best. Why do Americans have to blab on?
Yes looking on YouTube I found Oakys Garage M/C lacing is about the best video I could find (not that I have done any lacing yet).
Cheers... AshD
Offline matthewmosse
« Reply #18 on: February 14, 2014, 03:27:03 PM »
copying an exsisting wheel is best, lots of photos is probably fine, it is not that hard, so long as you take your time, even I can do it - tested my results by using the wheel on a sidecar for 50k miles.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #19 on: February 14, 2014, 03:42:39 PM »
I found it very easy as the hub had marks from the previous spokes.
« Reply #20 on: February 14, 2014, 04:28:58 PM »
To those interested i will explain now but anybody is welcome to email me, just don't expect a quick answer due to working hours.
There are two types of spokes  20 of each and the length from bend to head is different
(1) you can see the head from the out side so it goes out to in
(2) the head is on the inside so it goes in to out
Take the 20 of type (1) and using your picture lace up the wheel with just those and get all evenly tight and true the wheel
I put the wheel spindle in a big vice and spin the wheel using a large screwdriver to judge up and down and lateral error
When doing this note that anything less than 1/8 inch is good and look at the rim to see where it has been welded together as this frequently causes a "kick" that can never be trued out but you will go mad trying.
with the wheel trued this way---a lot easier as you are only playing with 20 spokes you can now fit the other 20 one at a time as they will happily fit from inside to outside without fouling anything.
Tighten evenly and check for runout.
The first time you do this expect to spend 2-3 hours on the job but after a few you can get it down to 1/2 hour
I have found with genuine or DSS kits that it is easy to get the rim fairly true by just winding the nipple on the same amount as they are very uniformly made
Hope that helps and have a fun, frustrating time
Offline kmn
  • Guilty of the wilful neglect of CB500/4. Sorry.
« Reply #21 on: February 19, 2014, 09:25:29 AM »
Many thanks - I'll get the rim & spokes ordered this week and let you know. What is life without a challenge, or 40 of them...
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
« Reply #22 on: February 19, 2014, 12:42:26 PM »
couple of docs and things I refferreed to:
I used following guides for the wheel building;
http://www.webbikeworld.com/motorcycle-wheels/spoke-wheels/
http://www.classicbikes.org.uk/ ..... wheel building page
1. Got loads of help from this forum and the US one
2. Cut the old spokes and rim off the hub
3. Polished outsides of hub and painted centres with etch primer and black epoxy paint
4. Worked out the difference between the two spoke types
« Last Edit: February 19, 2014, 01:04:59 PM by Ewan 500 K1 »
500K1 basket case for later
Offline Ewan 500 K1
« Reply #23 on: February 19, 2014, 12:58:04 PM »
5. Put the "B" spokes on the outside of the hub, ie poked them through the holes from the inside of the hub to the outside. Note that the pic is to only show arrangement of the "B" spokes only, I put all spokes on the hub before lacing any of them
6. Put the "A" spokes on the inside of the hub, ie poked them through the holes from the outside of the hub to the inside. below Note that the pic is to show arrangement of the "A" & "B" spokes only, I put all spokes on the hub before lacing any of them)
7. When all the spokes were on the hub, I sat the hub on a table and sat the rim over it and loosely arranged the spokes. Then, laced the A spokes on the speedo side hub to the rim and put the spoke nipples on a couple of turns. Then did the B spokes for the speedo side of the hub, Turn the wheel over, do the "A" spokes for the brake disc side, then the "B" spokes for the brake disc side , again putting the nipples on a couple of turns.. So, all spokes now roughly laced up
8. Made a truing jig out of an old pair of forks bolted to a work bench. Put the wheel the on the jig
« Last Edit: February 19, 2014, 01:08:24 PM by Ewan 500 K1 »
Offline Ewan 500 K1
« Reply #24 on: February 19, 2014, 01:02:36 PM »
9. Went round all nipples taking one off at a time, put a bit of oil on the female nipple thread and a bit of copper grease on the rim nipple seat. Then put the nipple back on and tightened it 10 turns with a cross head screwdriver. Worked round the wheel until all spokes / nipples oiled, greased and tightened 10 turns.
10. Used a dial gauge and spoke wrench to get the wheel true to 0.2mm vertical, then 0.2mm horizontal, then checked vertical again. .....Always starting at biggest high and low points and tightening spokes a  turn or so at these points and tightening adjacent spokes half a turn. This was fairly easy, taking about an hour or so to get trued up. (note that its impossible to get the rim true to this degree at the point where the rim weld is)
11. Job Done
« Last Edit: February 19, 2014, 01:10:16 PM by Ewan 500 K1 »
« Reply #25 on: February 19, 2014, 07:38:14 PM »
Good write up and pictures  Ewan, that makes a good reference for us on here.
I've always avoided doing these in the past but nice to see it layed out so clearly.
Thanks for your time and effort to show us.
Offline kmn
« Reply #26 on: February 21, 2014, 08:48:36 AM »
Indeed a thousand thanks Ewan, that can only be a massive help.
Offline kmn
« Reply #27 on: February 25, 2014, 11:14:21 AM »
Rim and spoke kit ordered from DS:
Now then.... it now appears - after taking it to bits - that I have been riding around on a CB450 hub for the last 20 years... Anyone got a 500 hub for sale?
Cheers!
Kev
