SOHC.co.uk Forums > CB750
Honda cb750k2 Carb opening machanism
JamesH:
Phil try google Picasa - you can import all of your images (it'll search your whole harddrive for them) and then you can select the images you want and then export - you can batch export several images and set the quality / size you want which should bring the individual file sizes down....happy to help on the carb front if Mick can't. J
mick:
Hi Phil I've had a look and I don't have those parts you need sorry , James may be able to help you ? cheers Mick ;)
philward:
Thanks for looking Mick - much appreciated
philward:
James
I've tried private msging you about those bits but msg doesn't send? (screen tust goes blank)
My mobile is 07793750144 if you want to txt me your number
philward:
Msg has gone - was me not looking in msgs properly!
Navigation
[0] Message Index
[*] Previous page
Go to full version
