Front brake caliper piston
Topic: Front brake caliper piston (Read 5587 times)
paul G
March 21, 2014, 12:47:43 PM »
Hi all,
Anyone got a spare decent front brake caliper piston
Re: Front brake caliper piston
March 21, 2014, 03:24:39 PM »
Get the Stainless repro from Dave Silver mate and fit a new seal, you only got one neck!!
paul G
March 21, 2014, 06:36:41 PM »
Think I'm going to Brian just thought I would ask first. Spent an absolute fortune with them and still can't get a penny discount
March 21, 2014, 07:23:30 PM »
Me neither mate, at least the SS replica is cheaper than a chromed original and will never rot
paul G
May 07, 2014, 01:53:13 PM »
Hi all,
Got the new piston and OEM seal but still got some weeping from the caliper.
Has anyone had any issues with the caliper body itself, it seems OK/clean enough.
Regards,
May 08, 2014, 07:51:33 AM »
Not had a problem on the piston unless seal was damaged but have had leaks on both pipe and nipple
Ewan 500 K1
jings crivens help ma boab
May 08, 2014, 07:15:50 PM »
Hi Paul,
Is it leaking at piston then ? .. not bleed nipple or brake line entry point ?
Were you scrupulous about cleaning out the groove for the seal ?
Did you put some red grease on the seal ?
Last Edit: May 08, 2014, 07:30:11 PM by Ewan 500 K1
500K1/550K3 mongrel cafe racer project for now at
http://www.sohc.co.uk/index.php/topic,4120.0.html
500K1 basket case for later
