SOHC.co.uk Forums > CB500/550
CB550F Carbs
<< < (4/4)
Bryanj:
When you build the carbs up onto the bracket don't forget the small steel pin at the bottom inbetween 2 and 3 or there will be nothing to hook the return spring onto.
Been there, seen that, watched the video and destroted the T shirt in frustration!!!
Oldiron550:
I know the exact one, it was on the bench when I gathered all the bits up.
Sent from my iPad using Tapatalk HD
Oldiron550:
Where’s the best place to buy new floats for my 1976 CB550F?
CMS have them approx £35 each!! If I’m reading it correctly? or maybe i could clean the old ones Ill post a photo later.
Trigger:
Just clean the old ones by hand. Throw them in water and if they float, they will be OK.
Oldiron550:
Looks like they will clean the very best, I submerged them in water for 15 min's they all still float no sinkers. Once I get my new carb leaf springs & pins eat a few Easter eggs then I'll crack on with my carb build!
Navigation
[0] Message Index
[*] Previous page
Go to full version
