Author Topic: Keyster carb kit  (Read 10958 times)
Offline RGP750
Keyster carb kit
« on: April 09, 2014, 08:03:05 PM »
Hi all ,not wanting to hijack Steff's KO carb problem, just
noted Seamus has commented Keyster carb parts not good on sohc 's
Having just paid DS £80 for a set and rebuilt the carbs ,if this comment founded,
has anyone else used keyster and had no problems.
concerned of Ashford :-\
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Re: Keyster carb kit
« Reply #1 on: April 09, 2014, 08:18:01 PM »
RGP,
Yep its all true I bought keysters and like I always say pattern is SHIT.HAD NOTHING BUT PROBLEMS.Sourced what genuine bits I could get reused what I had and guess what?Runs like a dream.Try and stay away from keyster even the crowd across the pond slag them off.Sorry to be the bearer of bad news but I too learnt the hard way
Bitsa
Offline RGP750
« Reply #2 on: April 09, 2014, 08:31:31 PM »
Deep joy, Thought with him selling it it would be ok,.Looks like another wad wasted then.
Suppose i'll give them a call and see what they have to say.
Recon i'll put the original parts back then. :(
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #3 on: April 09, 2014, 08:37:05 PM »
RGP,
Already done that and I got well we have had no complaints so far.Number one the slide will not bottom out unless the needle is set at max height.Jets are jets,the air screws look like nothing to the originals.It has something to do with the taper of the needles not the same, shame it only seems to be the 750 kits I have heard
Bitsa
Offline RGP750
« Reply #4 on: April 09, 2014, 08:47:27 PM »
I'll strip one down again and do some comparisons,and dimensional checks.
Good job i didn't bin the originals.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline Oldiron550
« Reply #5 on: April 09, 2014, 11:14:18 PM »
I'm in the midst of rebuilding my CB550 carbs, I got a set of Keyster's from DS ages ago, crap!!
Should I clean the originals a sticking them back in?
Current Bikes
1976 CB550F
1972 BMW R60/5 SWB
1947 BSA M20 (girder forks)
Offline Norniron
« Reply #6 on: April 09, 2014, 11:22:16 PM »
Try them out first,i never had any problems with any keyster kit i have used.
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline RGP750
« Reply #7 on: April 10, 2014, 06:49:33 AM »
as Bitsa says it only seems to be the 750 sets.
no replies with success with these yet on 750s,
interesting to see if any come.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #8 on: April 10, 2014, 12:15:31 PM »
Bought a complete kit from 'keyster' in 2009 and had problems, no matter where I set the clip's on the needle jet's, the bike would start, but no power/steam running from exhaust vents (too lean)
The K4 requires a 105 needle/main jet's which I ordered from DS, set the needle's at the mid point, and its been fine.
I thought the issue could be that 'keyster' have machined the needles to suit the early models 110/120 jet sizes???
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline RGP750
« Reply #9 on: April 10, 2014, 01:02:54 PM »
Thanks Alan
Mine is a K2 and has a 110 in the kit,good or bad i don't know.
I'll measure the originals with the new ones tonight and get a comparison.
Rich
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #10 on: April 10, 2014, 01:22:33 PM »
I dont think it has anything to do with the jet size cant remember what its called but its the bit in the centre of the carb that the needle goes up and down in and the needle taper sticks in it.
Bitsa
Offline RGP750
« Reply #11 on: April 10, 2014, 02:19:10 PM »
I know from memory it's longer than the original.
I'll check needle length/diameter when i get home
and see how it compares with original.
I'll report back later.
Rich
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline RGP750
« Reply #12 on: April 10, 2014, 05:51:32 PM »
checked Keyster against original and find everything i can check within .002".
heights,position etc.
Could there have been an issue that has been resolved?
Do i put the old stuff back in or take a chance and maybe have to take the carbs off
when i finish the rebuild.
Decisions Decisions.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #13 on: April 10, 2014, 07:14:43 PM »
Hi Rich,
Possible the problem has been resolved after complaints. If you PM me with your address, I can send you the 'keyster' 4No. needles/jets so that you can make a comparison. From memory the 'keyster' needles where much thick that the Honda needles.
Alan
Current bikes:-
« Reply #14 on: April 10, 2014, 08:23:36 PM »
Just built my K2 carbs up with Keyster parts - didn't mic them up but next to each other they looked same length. They are in now so wont know until start up and that's ages off - when Silvers gets some repo exhausts in stock!
