SOHC.co.uk Forums > CB750
cb750 cam timing
Bitsa (Ralph Wright - RIP):
Photos and will let you know.Why are you using a timing disc for?Hondas have it all there for you.
Bitsa
750rideruk:
Job sorted.
Cam chain had come off the crankshaft sprocket. Removed barrells and heads replaced and hey presto everything aligns
Yep
Had that happen to me once but with a lot of poncing about got it back on the crank without removing cylinders and head,
Well done hope all goes well for you,
Bitsa
steff750:
;) yes we all done it I think at some time, but knowing it is off the sprocket is the trick I always try and keep tension on the chain so no slack is at the bottom of chain
as bitsa says a lot of poncing about .
but it will go back on no problem without removing the head or barrels
but that being said you need to know that it is off the crank anyways ::)
Steff
Spot on mate I test it by pulling on the chain if its not on the crank it justs keeps pulling without any thing moving and hurts your hand like fury.
Bitsa
Navigation
[0] Message Index
[*] Previous page
Go to full version
