chassis plate
Topic: chassis plate (Read 7355 times)
MikeM
SOHC Expert
chassis plate
April 21, 2014, 09:35:01 PM »
this was taken off by powdercoaters........ whats the best way to re-attach and where abouts does it go again
was looking through my old pics and cant find any points or marks on bike where it might have been ...... near the battery cage ?
MikeM
SOHC Expert
Re: chassis plate
April 21, 2014, 09:44:41 PM »
k3 78..... just found this pic I took a bit blurry
is it just rivetted on..... think there is a raised plate on the frame ? probably wrong
Trigger
Re: chassis plate
April 21, 2014, 09:44:49 PM »
Don't think Mikes is a import oddjob. Goes by the battery Mike.
MikeM
SOHC Expert
Re: chassis plate
April 21, 2014, 09:50:48 PM »
so how do you normally refit? cant see where the holes where as powdercoat is quite thick
Trigger
Re: chassis plate
April 21, 2014, 09:55:44 PM »
There is special rivets for the job that hammer in.
MikeM
SOHC Expert
Re: chassis plate
April 21, 2014, 09:59:28 PM »
are these rivets from ds..... whats the method for refitting the plate
Trigger
Re: chassis plate
April 21, 2014, 10:00:44 PM »
From your picture i can't even see the rivets or the holes in the plate. I have known people to pop rivet them on, Use self tappers and once i had one that had been glued on.
Trigger
Re: chassis plate
April 21, 2014, 10:03:15 PM »
Part number 90841001000 for rivets i think.
Ecks
Newbie
Re: chassis plate
April 29, 2014, 07:21:44 PM »
I used stainless pop rivets for mine. Aluminum rivets will set up galvanic corrosion with the steel frame, so best to go with the SS variety.
MikeM
SOHC Expert
Re: chassis plate
April 29, 2014, 07:36:03 PM »
what size rivets did you use
thanks
peterengland
SOHC Member
Re: chassis plate
Reply #10 on:
May 01, 2014, 05:56:43 PM »
Araldite is fine for this apparently
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
chassis plate
