front axel diameter?
Topic: front axel diameter? (Read 5253 times)
rickni
Newbie
gettin there! it's always gettin there..
May 02, 2014, 01:12:37 PM »
Need too order bearings! Anyone know Off hand is front axel 20mm for cb550... Cheers
rickni
Newbie
Re: front axel diameter?
May 03, 2014, 11:05:46 AM »
Thanks but am using a different make Off wheel! Outside diameter of bearing is 42mm,
Haven't bout an axel yet tho.
rickni
Newbie
May 04, 2014, 07:55:42 PM »
thanks for the help!
anyone got an axel they could measure!
rickni
Newbie
May 05, 2014, 07:04:04 PM »
Cheers thanks!
ttr400
SOHC Associate
May 07, 2014, 11:41:30 AM »
Just to clarify this before you buy the wrong bearings. the front axle is 15.0mm diameter and uses a 6302 bearing. this is also the same for the other Honda 4 models.
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
