SOHC.co.uk Forums > CB500/550
Triggers bucket
<< < (11/11)
Ewan 500 K1:
--- Quote from: trigger6969 on May 09, 2014, 04:23:14 PM ---The next question is what 750?. Most of the 750K had a caliper that bolted from the back, until the K8 which had a front bolted caliper. The K8 shared the same caliper as the 750 F1. The 750 F2 had a totally different set up, shared with the 750KZ and KB. I have never seen this arm with the 50mm space on any 750's. There must be someone who has this 50mm/wide body caliper fitted. Come on now, don't be shy.
--- End quote ---
I've asked the  over on the 750 page trig.. using pptom's photo
Trigger:
Ewan, if it comes back with there from a special sand cast, i will give you a fiver for our 50mm arm ;)
Ewan 500 K1:
pptom .. if your still about have  gander at the answer at http://www.sohc.co.uk/index.php?topic=6573.0.  Yer man might be quite happy with his potentail resale price :)
pptom:
Just read that Ewan, thanks very much - coming to an auction site near you soon...
hairygit:
The bolt spacing on my 750F1 is 50mm, the 750K7&8 also use the same caliper. Until D.S.S. had some replicas made recently they were really hard to find in useable condition. So Trig, either get a 750F1/K7 or 8 disc, or sell the caliper and arm and fit 500/550 items, the 750 caliper also uses a marginally bigger piston and seal, and the seal is 3 times the price of the 500/550 item!
Sent from my GT-S5839i using Tapatalk 2
Navigation
[0] Message Index
[*] Previous page
Go to full version
