SOHC.co.uk Forums > CB750
Top yoke replacement
Bryanj:
I thought that the F2 had bigger diameter fork tubes
UK Pete:
--- Quote from: Bryanj on May 16, 2014, 05:57:20 AM ---I thought that the F2 had bigger diameter fork tubes
--- End quote ---
They are 35mm so should be the same dim
pete
El__burro:
--- Quote from: MarkCR750 on May 08, 2014, 11:04:42 PM ---EB, David Silver sells tappet caps and Honda CBX1000 Yokes are a straight swap, cheers Mark.
https://www.davidsilverspares.co.uk/CB750K2-FOUR-1972/part_105133/
--- End quote ---
Mark, is it just cbx1000 or also 750/500 models.
Bitsa (Ralph Wright - RIP):
If you have the k2 clocks they will not fit on to nothing else except the rhino yoke hope you have considered this
Bitsa
El__burro:
My intention is to "shave off" the raisers as I have clip ons and the speedo mounted on the headlight.
The cbx one will be great as it will save me the shaving bit.
Regards
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
