CB750
Exhaust screw removal. Best idea
Topic: Exhaust screw removal. Best idea (Read 4209 times)
El__burro
SOHC Expert
May 15, 2014, 10:34:59 PM »
I am about to deal with removing damaged screw to remove the exhaust from the header.
So far I have managed to remove 3 out of 8 (almost easily).
I have now 5 damaged screw to remove, what is the best way to do this?
El__burro
neat street
SOHC Expert
Re: Exhaust screw removal. Best idea
May 17, 2014, 11:17:56 AM »
I would suggest weld a nut on the stud and undo, if you can soak the unit in diesel or similar, it may also help before you undo?
hope this helps
John
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Ewan 500 K1
jings crivens help ma boab
May 17, 2014, 01:59:25 PM »
I've used on a stud extractor to good effect to get stubborn studs out :
http://www.machinemart.co.uk/shop/product/details/pro57-4-pce-stud-extractor-set
but ... do you really need to get the studs out to remove the exhaust .... rather than just removing the nuts from the studs ?
Last Edit: May 17, 2014, 02:03:57 PM by Ewan 500 K1
500K1/550K3 mongrel cafe racer project for now at
http://www.sohc.co.uk/index.php/topic,4120.0.html
500K1 basket case for later
MarkCR750
Professional half wit and member
May 17, 2014, 03:09:50 PM »
If you have enough good thread to get 2 nuts on the same stud you can tighten one nut against the other and the turn the nut closest the engine anti clockwise, applying heat and penetrating oil to the stud may also help, obviously you risk shearing the stud or the thread on the casting, so if you don't absolutely have to remove the studs just leave them, there is less to go wrong that way!
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
CB750
