CB350/400
Jerking
Topic: Jerking (Read 6632 times)
hondatri
SOHC Associate
Jerking
June 22, 2014, 09:10:16 PM »
Hi Guys I am looking for some info on my 77 400/4. Whenever I let out the clutch I get a jerking as Drive picks up. On moving off I let in the clutch the drive takes up with a Jerking Thump same when changing gear. Otherwise riding is ok. Any suggestions appreciated.
JamesH
Re: Jerking
June 22, 2014, 11:15:30 PM »
Sounds like clutch needs removing and either cleaning or new plates...common if the bike has stood for some time unused..
Bitsa (Ralph Wright - RIP)
Re: Jerking
June 23, 2014, 10:08:48 AM »
Apart from chain tension are the bushes that the sprocket bolts on to ok?If they are knackered it will jerk in all gears
Bitsa
Re: Jerking
June 23, 2014, 06:04:15 PM »
Oddjob
If I remember right they look like the ones on the swing arm where the bottom rear damper bolts to.
Still think its called a bush
http://images.cmsnl.com/img/partslists/honda-cb400f-england-frame-group-1l-1m-2l-2m_bigma000080f01-5_81c2.gif
no 280 and 550
Bitsa
Last Edit: June 23, 2014, 06:08:48 PM by Bitsa
Trigger
Re: Jerking
June 23, 2014, 06:21:39 PM »
All this Jerking boy's. 280 is a bush.
Re: Jerking
June 23, 2014, 06:25:11 PM »
Thanks Trig
Bitsa
Trigger
Re: Jerking
June 23, 2014, 06:29:01 PM »
So Bitsa, is that 50p forgotten now???
Re: Jerking
June 23, 2014, 06:30:42 PM »
Trig
What 50 pence?Do you have that geezers number the one that fixs the clocks?
Bitsa
Trigger
Re: Jerking
June 23, 2014, 06:40:34 PM »
Bitsa, i am still on me hol's. If you key in
www.clocksndials.co.uk
it should come up. I know he started years ago because he could not find anyone to do his 750 clocks, so he did them himself.
Re: Jerking
June 23, 2014, 06:56:32 PM »
Oddjob
No worries mate I should have put rear, mind you check the front aswell for play but then again if it was that bad I would think the shaft seal would be leaking like hell
Thanks Trig have a good one mate
Bitsa
hondatri
SOHC Associate
Re: Jerking
Reply #10 on:
June 23, 2014, 07:11:49 PM »
Thanks Guys for the info I believe a new clutch was fitted shortly before I got bike but I wont take it for Granted. I will have a go at it in the next few weeks and keep posted. Thanks Again
CB350/400
Jerking
