Author Topic: weak spark  (Read 5622 times)
Offline neat street
weak spark
« on: June 27, 2014, 02:17:56 PM »
I All, I am having problems in starting my CB750F1, the spark seems weak? I have changed the coils, points, condenser's, plugs and caps, it does coke up a little as well, and after setting the timing and carb settings, the only thing left was the weak spark which would cause both issues. anyone got any ideas please?
many thanks, John
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Re: weak spark
« Reply #1 on: June 27, 2014, 02:24:17 PM »
Have you tried bypassing the handlebar kill switch, it's not unknown for these to become dirty/corroded inside and cause starting/running problems?
Offline UK Pete
Re: weak spark
« Reply #2 on: June 27, 2014, 07:13:31 PM »
+1 on that, also clean all earth contacts
pete
Offline neat street
Re: weak spark
« Reply #3 on: June 27, 2014, 08:59:44 PM »
Thanks for the tips, but switches were stripped, cleaned, painted and rebuilt, all earth connections checked when the bike was rebuilt a couple of months ago, I am baffled??? its a pain to start, but when it starts (a few misfires), it drives like a dream, but after stopping for a couple of hours, same problem of not wanting to start again... check plugs, and light coking, check spark and its weak??? starting from hot, perfect!
Many thanks, and hopefully some more tips would be appreciated.
John
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
weak spark
« Reply #4 on: June 27, 2014, 09:14:31 PM »
Have you done a compression test cold / hot john? Valve clearances all spot on?
Re: weak spark
« Reply #5 on: June 27, 2014, 10:48:07 PM »
Check coil voltage with an accurate meter , also at points wires when disconnected it's not unknown for the leads to go high resistance due to length of wire and connections
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Lobo
« Reply #6 on: June 27, 2014, 10:56:55 PM »
Hi John,
Whilst you replaced the coils did you actually check / replace with spec coils? Have you actually put a meter across the various wires to confirm good earths, 12v & so on?
You seem convinced its a spark issue... so here from my CB750 K series manual if of any help.
(The manual also includes supplements for subsequent F models.... no changes to the ignition system tat I can see...)
Cheers,
Simon
« Last Edit: June 27, 2014, 11:11:58 PM by Lobo »
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: weak spark
« Reply #7 on: June 28, 2014, 07:52:06 AM »
Further thoughts...
(Morning Bryan. Sorry - doubled up on your suggestion, my posting being typed as yours registered. Only just seen it..)
IF your spark is weak, for whatever reason, it signals a 'lack of electricity' for want of better words.
I'm not familiar with the F1, but suspect the wiring is not far off most SOHCs of that time, but please, do check before trying this.
The battery positive goes to a fuse box, up through the steering head to the ignition, through the handlebars to the kill switch, back through the bars / steering head & finally to the coils. (The wiring likely changes red to black to black / yellow along the way). Anyways, a few loom plugs, switches & a 35yr twisting loom... all hurdles.
What I'm suggesting is a direct jumper wire from the battery positive to the coils +ve. You don't need to disconnect anything else... just run that lead. (leave the kill switch @ OFF throughout this test). Beware now though that the coils are permanently ON, ie don't leave them in this state too long & disconnect the jumper soon after the test. Most importantly DO NOT ride the bike as no way of stopping the engine should you come off ...other than choke perhaps.
Yet more thoughts (don't know the F) is regarding the main beam... is this on with ignition & 'sapping' electricity during cranking? If so remove the head / tail bulbs & try.
The starter motor / battery... are these in tip-top shape... a worn starter may drop the battery voltage right down & really weaken the spark. My K2 was originally wired (po) lights ON @ ignition... it made a significant difference to firing up.
Finally, how familiar are you with the bike? My K2 frustrated the hell outta me on cold starts, despite it having new 'everything' (inc carb set-up / jets). I still don't understand, but I've discovered that to cold start I dry crank it (kickstart) a couple of times, then full choke, wide open throttle (WOT) and press the starter. Amazing, I might have left it 4 months, but always fires up <2 seconds.
Cheers,
Simon.
« Last Edit: July 08, 2014, 02:23:29 PM by Lobo »
Offline neat street
Re: weak spark
« Reply #8 on: June 28, 2014, 09:49:45 AM »
Thanks for your help everyone, I now have plenty of things to check. I will up-date you all on the result.
Many thanks again. John
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
Offline neat street
Re: weak spark
« Reply #9 on: July 08, 2014, 12:52:00 PM »
Hi All
Thanks again for all your input, I think I found the problem in the handle bar switch, one screw was a little too long and earthing intermitently. all seems perfect.
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
