SOHC.co.uk Forums > CB500/550
exhaust stud ..... welding the head
MikeM:
I have used the m8x1.25x10.8 mm neilsen kit, used the drill and tap in the kit
aluminium seems really soft and wont take the tap for some reason hence the helicoil pulls out
am currently going down the route of replacing head as unable to get someone to weld and retap back to m6
Paull:
Hi MikeM
Aluminum is soft, compared to steel and helicoils are tempered steel to stop them snapping out.
It sounds as if you are running out of options, a good ali welder or a new head, sorry to say.
Paull
MikeM:
yeah i have a new head coming and a more experienced guy on it to repair mine
will be sorted shortly :)
Paull:
Cool Let us know how you get on.
Paull
Bitsa (Ralph Wright - RIP):
Mike
I had a mate Ali weld a spare alternator cover which had a hairline crack in it.When I got it back I was so surprised at how hard it was to grind down.So going on that basis your head if done the same way will come out as new and stronger.
Best of luck
Bitsa
Navigation
[0] Message Index
[*] Previous page
Go to full version
