Other Stuff > Misc / Open
What is it with me and DK?
singal.satish007:
Sorry bro my micrometer is jammed, hence I used the vernier. What is the standard sizes. Of cam lobe and surrounding.
Sent from my Redmi 4 using Tapatalk
AshimotoK0:
I think your problem is your cam is earlier than the one that uses 312 rockers as yours has a base circle of 30mm and the one that uses 312 rockers has a base circle of 33-34 mm . This is why you can't achieve the correct rocker clearances. Unfortunately, the 286 rockers are rarer and also much sought after by the CB350 classic racer fraternity.
If you look at the screenshot below I think your cam is the -050 version
I don't have any spare 286 rockers but I will look out for you. The alternative is to source a -060 camshaft, which are more common as used on late K2,K3,K4,K5 (disc brake model) and of course you could sell yours. It really depends what you can find ...i.e. 4 x 286 rockers or a -060 camshaft.
singal.satish007:
The attachment is not opening, can you send me a link please so I can confirm it.
AshimotoK0:
--- Quote from: singal.satish007 on May 13, 2020, 01:59:14 PM ---The attachment is not opening, can you send me a link please so I can confirm it.
--- End quote ---
https://www.dropbox.com/s/4kbqy9647cpm2ym/CB350%20cam.JPG?dl=0
The combined CB350K Parts Book scan (essentially a bored out CB250 engine) is here:
https://www.dropbox.com/s/2ohbdtqh5nvgvvf/Combined%20Honda_CB350_Parts_Catalog.pdf?dl=0
singal.satish007:
Thanks for all your help bro, this is suspense from almost a year cause not getting time to chk it thoroughly. For this I have dismantled engine twice,,
Thanks once again bro
Navigation
[0] Message Index
[*] Previous page
Go to full version
