SOHC.co.uk Forums > CB750
Starter clutch
steff750:
--- Quote ---I think that the Phillips screws that hold the hub in the clutch is very difficult to loosen
--- End quote ---
if you are referring to the screws on back of alternator there is no need to remove them you will be ok with them in place
sand5858:
Hello, All.
Many thanks for your advice, I will try to change the rollers on the starter without removing the screws behind the generator.
thank you
Tony 8)
Bryanj:
Cange rollers, springs and spring caps all at the same time mate, I think DSS does them as a "KIT"
sand5858:
Hi Bryan.
Thank's but i have already buy'ed a starter kit. Now I just need to synchronize carburetors 4 cables on my Sandcast it is the last missing.
Thank you
Tony
Navigation
[0] Message Index
[*] Previous page
Go to full version
