SOHC.co.uk Forums > CB500/550
How many rattle cans?
<< < (4/4)
Trigger:
What you must take on board is that this is a 37 year old engine with no know history. I find it hard to comment on a engine unless i have been up close and personal with it. You may be lucky and press the button and it starts. For how long is hard to say.
I stripped a CB500 engine a couple of months ago to find the needle roller bearing on the end of the gear box had destroyed itself. The PO told me that it was a running motor but, yes it may have been a running engine with no gears. On the other hand i have stripped CB550 down and found it only needed new chains.
You can tell a lot about a engine from what is in the sump. I can see how much play is in the primary chain from looking in the engine with the sump pan removed but, no manual in the world has this type of information in it. It is a gamble.
I have no clue what your budget is for your project. But the lads on here always say, what ever there original budget was it went out the window a long time ago. I always over budget so not to get caught out.
Sorry for being honest.
JustcallmeMrT:
--- Quote from: trigger6969 on September 23, 2014, 10:47:44 PM ---What you must take on board is that this is a 37 year old engine with no know history. I find it hard to comment on a engine unless i have been up close and personal with it. You may be lucky and press the button and it starts. For how long is hard to say.
--- End quote ---
It's all good Trigger, I appreciate the realism.  I was hoping to get it done for £2000, but if not, then it'll just take longer.  I'd rather know it was done right than do a half job and have that doubt in my mind on a long ride.  It's not the time or money (within reason), I just don't want to tear it to pieces and realise I'm in over my head.
JustcallmeMrT:
--- Quote from: trigger6969 on September 23, 2014, 07:56:39 PM ---No problems. Have shared it before. Good stuff the Simoniz in all its paint range. MR Holts if your watching please send me a FREE Trade pack ;)
--- End quote ---
Do you use a primer first?
Trigger:
No primer needed but, the engine must be clean of any old paint, oil ,dirt and corrosion. The cleaner the better the finish. It's all down to the prep work.
Bitsa (Ralph Wright - RIP):
Aint it all the same Trig? same with women wine dine etc or you get crap all
Bitsa
Navigation
[0] Message Index
[*] Previous page
Go to full version
