SOHC.co.uk Forums > CB750
On A budget Rebuild cb750
<< < (21/24) > >>
Bitsa (Ralph Wright - RIP):
Thanks Hairygit that's what I thought
Bitsa
Bryanj:
Sorry peeps, I was COOOOLD and tired after a another 14 hour night and was thinking of the smaller chain driven starters, 450/500?, plus the 23/500 co-codamol were kicking in.
If a starter does not turn try using jump leads direct to starter casing and terminal first, if it still don't work its normaly brushes and a clean but with enough decent used ones out there that aint always worth it as you have to solder the brush braids if my memory is back working
No worries Bryan I cant remember whats for dinner and the olde lady told me this morning mate.Its probably the bushes as when it sat for 2 years in a jig tryed to get the oil to go around it span good for 10 mins then got less and less and now just clicks
Bitsa
Update on the starter motor with good advice from good olde or he thinks not so old Trigger did what he suggested and it now spins like a new motor.Took his advice as never had to replace or repair one of these been lucky.So nearly all done and will have it on the road b4 my 60Th just needs a ride to make sure but its shite weather now.
Thanks for everyones advice
Bitsa
Trigger:
--- Quote from: Bitsa on December 18, 2014, 07:13:49 PM ---Update on the starter motor with good advice from good olde or he thinks not so old Trigger did what he suggested and it now spins like a new motor.Took his advice as never had to replace or repair one of these been lucky.So nearly all done and will have it on the road b4 my 60Th just needs a ride to make sure but its shite weather now.
Bitsa
--- End quote ---
Well that saves me lugging one to he post office and it breaking the scales. I told you it was easy ::) ;D
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
