SOHC.co.uk Forums > CB500/550
It lives!
<< < (5/5)
Green1:
Trig do you have to lay it on its right side like the 750 if so don't forget to remove the points cover if its any good
Mick
JustcallmeMrT:
--- Quote from: Green1 on October 12, 2014, 04:30:13 PM ---Trig do you have to lay it on its right side like the 750 if so don't forget to remove the points cover if its any good
Mick
--- End quote ---
From the looks of it, most of the bolts will have to pull out from the right, so I think it'll have to be on the left.  Don't know if this is typical or just the way the P.O. assembled it.
matthewmosse:
Definitely has to come out of the right side of the frame, the engine bracketts only let it out that side. Note the bracket that holds the cluch cable on top right of gearbox, it comes off, on the left that long bolt goes through the frame so it will not fit through from that side.
JustcallmeMrT:
--- Quote from: matthewmosse on October 12, 2014, 04:41:33 PM ---Definitely has to come out of the right side of the frame, the engine bracketts only let it out that side. Note the bracket that holds the cluch cable on top right of gearbox, it comes off, on the left that long bolt goes through the frame so it will not fit through from that side.
--- End quote ---
Thanks for the tip Matthew, would have spent am age trying to pull it out the left side.
Trigger:
Yep, folks off. The less you have, then the lighter it is to lift the frame from the engine.
Navigation
[0] Message Index
[*] Previous page
Go to full version
