SOHC.co.uk Forums > CB500/550
Update on my 550 project
JustcallmeMrT:
--- Quote from: tom400f on October 31, 2014, 04:02:17 PM ---So now you have a (nearly) new engine you no longer need to strip the old one (I think you were musing, or was that someone else?), you can drop that straight in?
--- End quote ---
That's right, should drop straight in, just needs an oil change. Saves me stripping that other one and doing all the bearings and seals.
peterengland:
Do you know where I can get extra polishing bits for my Dremel? I can't seem to find any individual ones only packs of loads of bits, most of which I won't use.
matthewmosse:
Place by me had a huge display case of them, not looked recently but try Charlies stores online or ebay of course. I bought a selection set from Lidl, the other week, you get a lot more bits for £5. I am afraid my dremel died years ago,I now have a cheap version made by blackspur of all brands yet it was a fraction of the cost of a dremel and has done way more work. I recon you could buy the selection sets, remove the polishing bits and sell on the rest and it cost you less than genuine individual dremel bits. Needs costing up though as I haven't bought anything other than lidl cheap bits in years.
JamesH:
--- Quote from: Oddjob on November 04, 2014, 04:50:56 PM ---If like me, you like the fact that a Dremel (or for that matter, any tool similar in use to be called a "Dremel" ) can get into areas that a polishing mop can't then I can recommend buying the new SpeedClic system. There are 3 sanding flap wheels of varying grades which are fantastic, very very quick to change between them, literally seconds, they also have a proper polishing mop attachment, unlike those very poor bits of fluff which you screw onto what is basically a shortened self tapper. The system is not cheap but if you shop around you can buy each attachment for a LOT less than the price B&Q sell them for.
For me, the SpeedClic system is what Dremel should have used right from the start, just a brilliant piece of kit.
--- End quote ---
Oddjob have you got any photo / visual examples of where / how you've used the speedclick attachments with success??
royhall:
Polishings looking great. Just done my 750 cases so know how hard it is. Top job.
Navigation
[0] Message Index
[*] Previous page
Go to full version
