Author Topic: CB750F1 Project  (Read 71510 times)
Offline martin_uk
CB750F1 Project
« on: November 14, 2014, 01:35:03 PM »
Bought bike from friend who told me the engine was seized from standing and probably needed a light hone and rings!
2014_0425cb750B40028 by nitram2010, on Flickr
I think it has an early Honda worm drive
2014_0425cb750B40025 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750F1 Project
« Reply #1 on: November 14, 2014, 01:38:29 PM »
Head was badly corroded
2014_0425cb750B40023 by nitram2010, on Flickr
2014_0427cb750B40009 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline preyno2
Re: CB750F1 Project
« Reply #2 on: November 14, 2014, 01:39:53 PM »
Goodness me!
Where's it been standing, in the garden pond?
Re: CB750F1 Project
« Reply #3 on: November 14, 2014, 01:41:16 PM »
The last picture looks like someone is using the wrong tool to clean it up.
Offline preyno2
Re: CB750F1 Project
« Reply #4 on: November 14, 2014, 01:46:42 PM »
I don't know whether it's badly corroded or part of the piston ring has been bouncing about in the chamber
Offline martin_uk
Re: CB750F1 Project
« Reply #5 on: November 14, 2014, 01:54:18 PM »
Just a rotary wire brush, the metal had corroded so badly .
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750F1 Project
« Reply #6 on: November 14, 2014, 01:57:51 PM »
Can be repaired but, the cost would be sky high. It would need everything.
Offline martin_uk
Re: CB750F1 Project
« Reply #7 on: November 14, 2014, 02:04:22 PM »
Plus the right front engine mount is broken  >:(
2014_0502cb750B40094 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750F1 Project
« Reply #8 on: November 14, 2014, 02:06:40 PM »
You have a very nice mate that sold you that.
Offline martin_uk
Re: CB750F1 Project
« Reply #9 on: November 14, 2014, 02:10:36 PM »
Pistons took some shifting!
2014_0426cb750B40008 by nitram2010, on Flickr
Diesel soaking
2014_0426cb750B40001 by nitram2010, on Flickr
2014_0426cb750B40010 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750F1 Project
« Reply #10 on: November 14, 2014, 02:13:32 PM »
You  can see the engine looked quite corroded
2014_0417cb750B40017 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline matthewmosse
Re: CB750F1 Project
« Reply #11 on: November 14, 2014, 02:41:06 PM »
I had a cb550 head that had similar dammage. In my case a previous owner had broken all the top rings, several of which had smashed out of the top of the pistonand scratched and dented the head up something chronic. They had obviously been in there, removed most of the debris, sealed up again re using old gaskets and leaving bits of broken ring in the sump and blue gaskett goo behind as a calling card. I bought thd bike taxed and tested, rode it a bit and found it was ok to ride but if stalled when hot it wouldn't restart until cold. It also leaked oil, but it wax also cheap. I only found the dammage when deciding the oil leak should really be fixed. I bunged on a decent set of barrels and pistons from a scrap engine, and re used the well scarred head. It ran for years like that, never down on power or hard to start after replacing the wrecked pistons. It eventually dropped a valve, many years later. Still have the remains somewhere.
Offline UK Pete
Re: CB750F1 Project
« Reply #12 on: November 14, 2014, 04:17:22 PM »
Blooming heck fella that engine is a very bad starting point,
pete
Offline cb ghia
Re: CB750F1 Project
« Reply #13 on: November 14, 2014, 05:44:39 PM »
What in the hell is that thing?  Is that a worm?  You must have very different worms on your side of the pond.
76 CB550
75 GL1000
Re: CB750F1 Project
« Reply #14 on: November 14, 2014, 07:33:06 PM »
Unbelievable, poor bike.
