Author Topic: CB750K8 Project  (Read 93911 times)
Re: CB750K8 Project
« Reply #135 on: March 04, 2015, 07:39:24 AM »
Best deal on valves I found were Kibblewhite valves from CycleX in the states. Good valves and still cheap even after postage and the dreaded import duty.
Offline martin_uk
Re: CB750K8 Project
« Reply #136 on: March 04, 2015, 09:05:39 AM »
Hi,
    Helicoil taps are a specific size to suit the helicoil, and most helicoil sets include the appropriate tap and fitting tool for each size of coils in the set!---ken
Thanks Ken
I suspected that was case but try to be an optimist  :D
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #137 on: March 06, 2015, 05:27:43 PM »
Helicoil/ V coil inserts and tap arrived today for M4 thread on carb float bowl screw.
2015_0306seat0018 by nitram2010, on Flickr
2015_0306seat0015 by nitram2010, on Flickr
Thread cut
2015_0306seat0012 by nitram2010, on Flickr
Made up inserter tool using ally roofing nail with slot cut in end
2015_0306seat0019 by nitram2010, on Flickr
2015_0306seat0020 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #138 on: March 06, 2015, 05:30:57 PM »
Fitted multi block connectors to handle bar switch looms
2015_0306seat0022 by nitram2010, on Flickr
Decided to go with new DSS replica headlamp bowl
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #139 on: March 11, 2015, 05:19:10 PM »
Finished cleaning up the head and found a nasty surprise in exhaust ports :'(
2015_0311eng0007 by nitram2010, on Flickr
2015_0311eng0008 by nitram2010, on Flickr
Very deep pitting, Im guessing caused by resting water over a long period of storage?
The head on K8 has F type exhaust fitting, but is not marked like a F1 with 392 cast mark,  but has K8 hand stamped.
2015_0311eng0009 by nitram2010, on Flickr
2015_0311eng0011 by nitram2010, on Flickr
Looks like I need to find another K8 or F1 head, as its going to be alot of work to weld up unless anyone knows of a fix to seal pitting and can cope with heat?
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750K8 Project
« Reply #140 on: March 11, 2015, 07:12:05 PM »
Martin, I cant really see from your pictures on how bad the ex ports are. If they are pitted, try to gas flow the ports.
Offline martin_uk
Re: CB750K8 Project
« Reply #141 on: March 12, 2015, 05:45:18 PM »
Picked up tank, petrol flap and side covers today ;D
Images dont fully show how good the colour is, as it really sparkles.
2015_0312tank0006 by nitram2010, on Flickr
2015_0312tank0001 by nitram2010, on Flickr
2015_0312tank0004 by nitram2010, on Flickr
2015_0312tank0007 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #142 on: March 12, 2015, 05:53:24 PM »
I may try grinding back to see how deep they are, could be welded and reground and sealing faces definately need attention.
Considered exhaust paste,  probably would work on the sealing face.
Will ponder ???
Due to get my original F1 crankcase that had broken top right engine mounting back from welders, which will need fettling as well.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750K8 Project
« Reply #143 on: March 12, 2015, 06:19:49 PM »
Paint's looking lovely martin. Great colour that....
Offline martin_uk
Re: CB750K8 Project
« Reply #144 on: March 19, 2015, 06:57:28 PM »
Thanks James, I now keep seeing similar colours on new cars  and thinking it was the right decision:)
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Project
« Reply #145 on: March 19, 2015, 07:13:55 PM »
Picked up the cylinders after rebore and asked the opinion of guy who is a very experienced engine restorer on exhaust port pitting and after viewing was not concerned, so I just cleaned up with die cutter.
Ended up fitting 2 ex and 2 in valves due to wear at stem top
2015_0318eng0013 by nitram2010, on Flickr
I went to +1mm, because I managed to find original Honda pistons and rings and thought it was overkill, but a shadow of the bore corrosion remains.
The specialist didnt feel it would be a problem so have fitted as they are.
2015_0318eng0008 by nitram2010, on Flickr
Last CB750 I did found cylinders dropped suddenly whilst assembling so took precaution of using some plastic paper binder cut down to limit travel.
2015_0318eng0003 by nitram2010, on Flickr
I used standard piston ring clamps which are a fiddle to remove after piston engaged, so have ordered the Honda part from DSS as I have 2 more engines to do ::)
2015_0318eng0004 by nitram2010, on Flickr
2015_0318eng0019 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline bytio
Re: CB750K8 Project
« Reply #146 on: March 19, 2015, 11:28:48 PM »
What piston to bore clearance did he do on REBORE?
Offline martin_uk
Re: CB750K8 Project
« Reply #147 on: March 20, 2015, 09:26:07 AM »
He said Honda clearance very tight, but as he has been doing the Honda engines since the 70's and worked with Dixons racing, left it to him.
I can find out if you need info.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750K8 Project
« Reply #148 on: March 20, 2015, 10:05:24 AM »
Martin - did you sort a set of  pipes in the end? I came a cross as set of 4 HM405 Original Sankei pipes lurking in the back of my garage last night (don't ask). I bought them to cut-down / modify the silencers for mock-megaphone 4-4 setup but looking at them it would be sacrilege to cut them up.
If interested I'll try and get some pics taken. They owe me a bit mind..
James.
Offline martin_uk
Re: CB750K8 Project
« Reply #149 on: March 20, 2015, 04:52:46 PM »
James.
Hi James
I am 3/4 there  ::)
Just need a HM405  No1 cyl  Left upper marked SL plus exhaust mounting brackets.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
