Author Topic: What's this hole / tube for?  (Read 16167 times)
Re: What's this hole / tube for?
« Reply #15 on: January 02, 2015, 09:24:35 PM »
That's the one Julie means, Steve
I bought 17335323000 from DSS - it has no pinch drain but since only the upper part was perished I used only that (or some such memory anyway). No idea why there is a "valve" in it at all. Perhaps to keep the crap out as there is likely no pressure or even some suction...
That part Number Tom is the air inlet breather pipe, so no valve. Unless anyone can tell me why the other has a drain valve, I think I will just order that one from DSS and stick something in the bottom that I can release every now and then. I could always stick a pea up it I suppose  ;D ;D ;D. Thinking about it, it must be suction actually, if you think of the direction the air flows around the system there must be some draw / vaccum up the tube, so if you go through a deep puddle, I wonder if water would get sucked in?
Regards
Julie
« Reply #16 on: January 02, 2015, 09:28:18 PM »
Just looked on DSS and the drain pipe from the air filter box with the pinch drain at the bottom is now an obsolete part. Does anyone know where else I can get this from?. Its Part No 17358-374-000. They still do the breather pipe from the bottom of the air inlet box which is handy as that's the one I'm missing completely.
Julie
measure the outlets and order Nitrile rubber smooth pipe ;)
Hi Trig
We use Nitrile rubber pipe at work but I've got a feeling what we use is a lot larger bore. Do you think it matters if it does not have the valve in the bottom ?
Regards
Julie
Offline tom400f
« Reply #17 on: January 02, 2015, 09:28:41 PM »
Oh OK. I remember wondering at the time because the nomenclature is ambiguous. Obviously I bought the wrong bit but... the pinch thing is separate and I reused the old one I had. It slips over the bottom of the tube, about 2cm long.
Not saying these were ever separate parts but hey, it's just a blind bit of tubing with a cut in the end. Perhaps something could be made...
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline tom400f
« Reply #18 on: January 02, 2015, 09:30:58 PM »
Go through a deep puddle ?  ;)
1978 CB400F2 Yellow
« Reply #19 on: January 02, 2015, 09:36:57 PM »
Julie
Hi Trig
Regards
Julie
Here is what i use>  http://www.ebay.co.uk/itm/140693835989?_trksid=p2055119.m1438.l2649&var=440044001332&ssPageName=STRK%3AMEBIDX%3AIT  But, make sure it is a tight fit. Most bikes have had the stopper thrown away yonks ago. These are only drain pipes.
« Reply #20 on: January 02, 2015, 09:38:21 PM »
Gosh, I never thought I would come across anyone else on this forum who knows about the 'ambiguity of nomenclature's '.You sound like my old Professor at Uni but he only rode a push bike, an old 1927 Dursley or something like that  ;D ;D ;D
« Reply #21 on: January 02, 2015, 09:43:09 PM »
What ever you do Julie, don't ask which way round the clutch cable eye goes. 400 Boy's can be a little sensitive ;D ;D ;D
Offline tom400f
« Reply #22 on: January 02, 2015, 09:55:22 PM »
Yes I think that was what finished bike-pusher off...  ;D
But then again, if you look at that routing diagram in the official manual it shows you .... oh well you know  ;D
And Julie - I did Physics at Uni. Well someone has to and us 400F riders are a broad church ::) :P
1978 CB400F2 Yellow
« Reply #23 on: January 02, 2015, 10:17:11 PM »
Don't you worry about my clutch cable eye, it's totally original and looks like it's in the right place and the right way round. Make of that what you will  ;D ;D ;D
Offline Dan
« Reply #24 on: January 03, 2015, 01:37:15 AM »
The pinch valve stops muck / water getting sucked up the hose. The hose also provides a place for any moisture / oil from the airbox to sit in until service time when you pinch the bottom of the hose and allow the oily residue to drain out. This type of hose is also on my more "modern" '94 Gixxer and is in the service routine in the workshop manual to drain it (Its a bung rather than a slit).It's surprising how much actually comes out the hose if the bike is used regularly and you only drain the hose at service time. I guess the 400 hose would have to be not perished at all to hold any oil or water.
Dan
1994 GSXR750WR Endurance rep
1975 CB400F ongoing project
Offline martin_uk
« Reply #25 on: January 03, 2015, 10:22:25 AM »
I previously had a 400/4 and tried to find the correct tube with pinch/duck bill type end.
I seem to remember buying one from India for a Royal Enfield, but dont remember if it fitted.
I believe the idea is that excessive pressure will open the duck bill, but if low pressure, will close bill and stop unfiltered air entering?
What size is the outlet on breather trap?
I will have a look to see if I still have.
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #26 on: January 03, 2015, 08:05:42 PM »
Thanks Martin, problem solved, I found some pipe that fits whilst out and about today. I would have preferred to have got hold of an original one if I could, but this will do just fine for the forseeable
Regards
Julie
Offline martin_uk
« Reply #27 on: January 03, 2015, 10:40:53 PM »
Found the pipe, it is 10mm inside.
2015_0103armse0017 by nitram2010, on Flickr
2015_0103armse0016 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
