SOHC.co.uk Forums > CB500/550
Bearing not budging
Bitsa (Ralph Wright - RIP):
Try the other end but use something solid like a socket set T bar never fails for me then go back to the other side and find something thats more or less the same size like a socket and hit it
Best of luck
Bitsa
Trigger:
More heat needed. You need to get the bearing red. Not sure what you are using for heat ?
JustcallmeMrT:
--- Quote from: Trigger on January 25, 2015, 07:08:22 PM ---More heat needed. You need to get the bearing red. Not sure what you are using for heat ?
--- End quote ---
A cheap parasene blowtorch.
Trigger:
--- Quote from: JustcallmeMrT on January 25, 2015, 07:25:10 PM ---
--- End quote ---
--- End quote ---
That is not going to get enough heat. Pop it in the oven at 220c for a hour and make sure all the windows are open and your smoke alarms are of. If it doesn't budge after that, you will need a stronger blow gun.
Trig
Master chef as well you never fail to amaze me ;).Whats the settings for sausages mate?
I have never done any of that must be lucky.The only thing I have done is to un sieze a brake piston a tip from a Canadian I might add is put the whole thing in boiling water for 10 Min's then air blast it and have to say popped straight out and its on my second bike works well
Bitsa
Navigation
[0] Message Index
[*] Previous page
Go to full version
