Author Topic: Brake calipers  (Read 14323 times)
Re: Brake calipers
« Reply #15 on: February 02, 2015, 06:20:21 AM »
Not too late for grease gun but those drilled holes worry me
Offline El__burro
Re: Brake calipers
« Reply #16 on: February 02, 2015, 08:15:29 AM »
Erm... There is a hole in the middle of one of them...
El__burro
Offline tom400f
Re: Brake calipers
« Reply #17 on: February 02, 2015, 10:20:50 AM »
Well, OTOH, if the pistons are corroded in that bad even if you dropped them in diesel for a week and grease-gunned them out, would the surfaces not be so bad they were scrap anyway? Just asking...
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Re: Brake calipers
« Reply #18 on: February 02, 2015, 12:53:08 PM »
You never know until you get the pistons out ;)
Offline tom400f
Re: Brake calipers
« Reply #19 on: February 02, 2015, 01:12:31 PM »
True
Just the bleeding heart in me, that's all...  :-[
1978 CB400F2 Yellow
Offline El__burro
Re: Brake calipers
« Reply #20 on: February 26, 2015, 09:40:54 AM »
Do K1 callipers fit k2?
Re: Brake calipers
« Reply #21 on: February 26, 2015, 10:03:35 AM »
Same Caliper. I never received those damaged ones through the post.
Offline steff750
  • THE POWER OF DREAMS
Re: Brake calipers
« Reply #22 on: February 26, 2015, 05:52:37 PM »
Quote
Bloody hell that's one hell of a mess
 ;) yes i can agree on both counts
1 they are f***ed
2 the grease gun works
don't under estimate the power of grease guys, ive seen that stuff keep the tracks pumped up on 300 ton diggers
Offline El__burro
Re: Brake calipers
« Reply #23 on: February 26, 2015, 06:19:25 PM »
These calipers are on the way to you Trigger.
I have just bought a new (used) one
It seems to be in good condition. I'll have to extract the pads somehow.
El__burro
Re: Brake calipers
« Reply #24 on: February 26, 2015, 06:55:28 PM »
That caliper will still need a full strip with a new piston and seal.
I look forwards to a play with those. I recon that i can alloy wield them up and a bit of machining.
Offline El__burro
Re: Brake calipers
« Reply #25 on: June 04, 2015, 11:06:08 PM »
Are the spring on the callipers all the same, can they be replaced with other type.
Although they are relatively cheap, with Vat and p&p still over £10 for 2 springs...
El__burro
Offline El__burro
Re: Brake calipers
« Reply #26 on: June 05, 2015, 02:54:31 PM »
Any ideas on how to get the bolts out of this calliper?
El__burro
Re: Brake calipers
« Reply #27 on: June 05, 2015, 05:27:35 PM »
Gentle heat and a well fitting allen key, if all else fails you can drill the heads off with a drill that just fits in the hole then etract the left over bits with vise grips
Re: Brake calipers
« Reply #28 on: June 05, 2015, 06:05:53 PM »
Or weld an old Allen key to the bolts
Offline El__burro
Re: Brake calipers
« Reply #29 on: June 05, 2015, 07:11:37 PM »
Some heath and a perfect fit allen key did the job. Thanks a lot Bryanj.
