SOHC.co.uk Forums > CB750
Brake calipers
ginger_jim:
I've always found connecting the calipers to a master cylinder and pumping does the trick. Isnt this the same caliper?
http://www.ebay.co.uk/itm/Cb750-K3-K4-K5-Brake-Caliper-/141680943727?pt=LH_DefaultDomain_3&hash=item20fcd7a26f
Interesting technique however! :o
El__burro:
that was sorted with a grease gun.
if only id find out before screwing the first 2 callipers.
thanks ginger_jim, your technique would have also worked greatly.
P.S. is it necessary replacing the rubber washer in the piston slot?
regards
el__burro
Johnwebley:
--- Quote from: El__burro on June 09, 2015, 10:40:23 AM ---that was sorted with a grease gun.
do you mean the seal ? it is a square section rubber ring.they used to cost about £3,and fitting a new one
will improve piston retraction and seal ,well worth doing
regards
el__burro
--- End quote ---
royhall:
I always use an old master cylinder and hose to pump them out, saves cleaning the grease out afterwards. Also its easy for a newb to damage the threads as they aren't really compatible and easy stripped.
Sent from my Nexus 7 using Tapatalk
Bryanj:
If you mean the piston seal think of it this way---You only have one neck and if that fails you have no brake
Navigation
[0] Message Index
[*] Previous page
Go to full version
